I am not getting any logs when I set the log level as err. When I give 503 req manually also, the acl failure_request not works it seems as I don’t see any logs in /var/logs/haprxy/error.log But if change from err to info i see some logs. Why it is not working? I am newbie to this community, Someone please help me ![]()
Global configuration
log 127.0.0.1:514 local0
log 127.0.0.1:514 local0 err
ssl-default-bind-ciphers ECDHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-GCM-SHA384:EECDH+aRSA+AES+SHA256:EECDH+aRSA+AES+SHA384:AES128-GCM-SHA256:AES256-GCM-SHA384:RSA+AES128+SHA256:RSA+AES256+SHA256:EECDH+aRSA+AES128+SHA:EECDH+aRSA+AES256+SHA:RSA+AES+SHA:!aNULL:!eNULL:!LOW:!MD5:!EXP:!PSK:!SRP:!DSS:!3DES
Default SSL material locations
log-format “%ci:%cp [%tr] %ft %b/%s %TR/%Tw/%Tc/%Tr/%Ta %ST %B %CC %CS %tsc %ac/%fc/%bc/%sc/%rc %sq/%bq %hr %hs %{+Q}r”
timeout connect 5000ms
timeout client 50000ms
timeout server 50000ms
Frontend and backend definition
frontend http_front
acl failed_request status 400:409 429 500:503
http-response set-log-level err if failed_request
use_backend servers if { hdr(host) -i localhost }
default_backend servers
backend servers
# balance source
# # option httpchk GET /healthcheck
# server server1 172.19.0.2:80
# server server2 172.19.0.3:80
# server server3 172.19.0.4:80
# server server4 172.19.0.5:80
server nodeserver 17.0.0.1:8082
bind :8080
stats hide-version
stats uri /
stats auth admin:sriram78
rsyslog conf (/etc/rsyslog.d/49-haproxy.conf)
$ModLoad imudp
$UDPServerAddress 127.0.0.1
$UDPServerRun 514
Creating separate log files based on the severity
local0.* /var/log/haproxy/access.log
local0.err /var/log/haproxy/error.log
Request I gave:
curl http://localhost:80/
503 Service Unavailable
No server is available to handle this request.Still i dont get logs in /var/logs/haproxy/error.log
