Hi community!
haproxy version: 2.3.0
method: haproxy-container from docker hub official image.
I got 2 backends with similar and simple configuration and the fisrt one when container is down / up i got the notify email of checks down/up
But with the second when i try down / up… just receive DOWN notification email… but NOT UP.
the configurations to check is here below.
what i’m missing.???
thanks in advance
# Backend: MediaWiki test
backend mediawiki_be_https
option httpchk HEAD / HTTP/1.1\r\nHost:\ localhost
email-alert mailers apsmailer1
email-alert from alert.mng."$DOCKER_ENGINE_NAME"."$THIS_CONTAINER_NAME"@example.com
email-alert to alerts.haproxy@example.com
email-alert myhostname smtp1
email-alert level info
cookie SERVERID insert indirect nocache httponly secure
server mediawiki mediawiki:8080 check inter 5s weight 50 id 1 cookie mediawiki_
# Backend: Vault devel
backend vault_be_https
server vault vault:8200 check inter 5s weight 50 id 1 cookie vault_
in the site statistic of haproxy I can see the UP backend but never get that notify UP email.
making check from CLI seams ok
curl -Is https://vaultdevel.localhost/v1/sys/health
HTTP/1.1 200 OK
