Simplified ACL for SNI matching
Hi There,
We are doing SNI based routing for multiple domains through our HAProxy LBs. but i need to add few more domains in the same HAproxy clusters.
But the domains are as mentioned below.
example.haproxy.com
example1.haproxy.com
example2.haproxy.com
example3.haproxy.com
example4.haproxy.com
example10.haproxy.com
Is there any easy way to group these domains in a single line acl?
Is it possible to configure like this?
acl application_5 req_ssl_sni -i example(1-10).haproxy.com
Please help.
It’s a normal ACL. You can match it against a file with a list of expressions, you can use regular expressions, etc.
Please read:
https://cbonte.github.io/haproxy-dconv/2.0/configuration.html#7
