For the server response when I did curl
* Expire in 0 ms for 6 (transfer 0x55e626cd3f50)
* Expire in 1 ms for 1 (transfer 0x55e626cd3f50)
* Expire in 0 ms for 1 (transfer 0x55e626cd3f50)
* Trying 192.168.1.119...
* TCP_NODELAY set
* Expire in 200 ms for 4 (transfer 0x55e626cd3f50)
* Connected to yahoo.com (192.168.1.119) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
* successfully set certificate verify locations:
* CAfile: none
CApath: /etc/ssl/certs
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to yahoo.com:443
* Closing connection 0
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to yahoo.com:443
For Haproxy tcpdump
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on enp0s3, link-type EN10MB (Ethernet), capture size 262144 bytes
10:49:52.679311 IP 192.168.1.117.47070 > localhost.localdomain.https: Flags [S], seq 1005535813, win 29200, options [mss 1460,sackOK,TS val 985724504 ecr 0,nop,wscale 7], length 0
10:49:52.679400 IP localhost.localdomain.https > 192.168.1.117.47070: Flags [S.], seq 1536868828, ack 1005535814, win 28960, options [mss 1460,sackOK,TS val 2801557 ecr 985724504,nop,wscale 7], length 0
10:49:52.679603 IP 192.168.1.117.47070 > localhost.localdomain.https: Flags [.], ack 1, win 229, options [nop,nop,TS val 985724505 ecr 2801557], length 0
10:49:52.679993 IP localhost.localdomain.https > 192.168.1.117.47070: Flags [F.], seq 1, ack 1, win 227, options [nop,nop,TS val 2801557 ecr 985724505], length 0
10:49:52.680860 IP 192.168.1.117.47070 > localhost.localdomain.https: Flags [P.], seq 1:518, ack 2, win 229, options [nop,nop,TS val 985724506 ecr 2801557], length 517
10:49:52.680907 IP localhost.localdomain.https > 192.168.1.117.47070: Flags [R], seq 1536868830, win 0, length 0
10:49:52.680919 IP 192.168.1.117.47070 > localhost.localdomain.https: Flags [F.], seq 518, ack 2, win 229, options [nop,nop,TS val 985724506 ecr 2801557], length 0
10:49:52.680926 IP localhost.localdomain.https > 192.168.1.117.47070: Flags [R], seq 1536868830, win 0, length 0
10:49:57.440416 ARP, Request who-has 192.168.1.117 (08:00:27:a3:cf:9e (oui Unknown)) tell 192.168.1.118, length 46
10:49:57.440841 ARP, Reply 192.168.1.117 is-at 08:00:27:a3:cf:9e (oui Unknown), length 46
