I am experiencing performance issues when downloading files through HAProxy, with download speeds typically ranging between 30-50 Kb/sec. However, when bypassing HAProxy and downloading directly from the SFTP server, I achieve speeds of 30-60 MB/sec.
Configuration Details:
I have two HAProxy instances configured with keepalived for high availability, redirecting traffic to my SFTP servers on port 22.
Additionally, I have configured HTTPS to access the application.
Is there a way to optimize the configuration to increase the download speed?
Configuration File:
For security reasons, I have replaced my IP addresses with “IP”.
log 127.0.0.1 local0
pidfile /var/run/haproxy.pid
maxconn 4000
timeout http-request 10s
timeout queue 1m
timeout connect 3600s
timeout client 3600s
timeout server 3600s
timeout http-keep-alive 10s
timeout check 10s
frontend my_app_be
bind IP:22
default_backend my_app_be
frontend https
bind IP:443
default_backend https
frontend smtp
bind IP:25
default_backend smtp
backend my_app_be
balance source
server node1 IP.132:22
server node2 IP.131:22
backend https
balance source
server node3 IP:443
server node4 IP:443
backend smtp
balance source
server node9 IP:25 check
server node10 IP:25 check
