Could you please help me?
i’m using :
Two VMs Haproxy 1.8 (open source) on Debian9 (and reparting the load between them with CRMsh/pacemaker/corosync) each one 3 vCPU and 12Gb RAM
When i set just one URL in the Frontend ACL and one Backend server it works fine.
but when setting many ACL in one frontend for different URLs that goes to different webservers/ports on different backends , the URLS opens very very slow and sometimes i get “503 gateway error”.
i tried playing with timeout connection/timeout server/timeout client but didn"t solved the issue… i tried setting each app in different Frontend a part… the same issue persists…
all webservers are Microsoft IIS… here is my config:
log 127.0.0.1:514 local0 warning
# turn on stats unix socket
stats socket /var/run/haproxy.stat
maxconn 80000
bind *:9999
maxconn 40000
stats hide-version
stats refresh 30s
stats show-node
stats uri /
#Front
frontend front_INTE_QA
log-format “%ci:%cp [%tr] %ft %b/%s %TR/%Tw/%Tc/%Tr/%Ta %ST %B %CC %CS %tsc %ac/%fc/%bc/%sc/%rc %sq/%bq %hr %hs %{+Q}r”
http-response set-header X-Proxy VMHAP1
bind *:443 ssl crt /etc/haproxy/certificates/ #no-sslv3
redirect scheme https code 301 if !{ ssl_fc } # redirect 80 -> 443 (for owa)
maxconn 40000
timeout connect 1800s
acl acl_app1 hdr(host) -i app1.domaine1.com
acl acl_app2 hdr(host) -i app2.domaine2.com
acl acl_app3 hdr(host) -i app3.domaine3.com
acl acl_app4 hdr(host) -i app4.domaine4.com
use_backend back_server1 if acl_acl_app1
use_backend back_server2 if acl_acl_app2
use_backend back_server3 if acl_acl_app3
use_backend back_server4 if acl_acl_app4
#Backend
server srv_myserver1 10.10.11.5:8089
server srv_myserver1 10.10.11.4:8088
server srv_myserver1 10.10.11.15:8045
server srv_myserver1 10.10.11.29:8050
