In one of my test boxes I upgraded to from 1.8 to 2+. After upgrade I get a socket error. I have 3 posgres db being managed by patroni. If I downgrade everything goes back to the norm. Below is my haproxy.cfg
Global settings
log 127.0.0.1 local2
pidfile /var/run/haproxy.pid
maxconn 4000
# turn on stats unix socket
timeout http-request 10s
timeout client 30m
timeout server 30m
timeout check 10s
maxconn 100
listen postgres
bind *:5000
option httpchk
http-check expect status 200
default-server inter 3s fall 3 rise 2 on-marked-down shutdown-sessions
server ah-1193063-001 30.167.223.9:5432 check port 8008
server ah-1193066-001 30.83.236.152:5432 check port 8008
server ah-1193068-001 30.83.222.28:5432 check port 8008
bind *:8088
stats uri /
stats refresh 5s
stats auth stats:statspass
