I am a follower of haproxy. I tested HTTP/2 fuction in haproxy_1.8.17 with the tool h2spec, but some test cases failed. I wonder if those are bugs for haproxy.
See the tool here https://github.com/summerwind/h2spec .
Those failed cases are as follow:
gaohd@host:~/.golang/gopath/src/github.com/summerwind/h2spec$./h2spec http2 -h www.axddos.com -p 443 -t -k
Failures:
Generic tests for HTTP/2 server
- Frame Definitions
3.10. CONTINUATION
× 1: Sends a CONTINUATION frame
-> The endpoint MUST accept CONTINUATION frame.
Expected: HEADERS Frame (stream_id:1)
Actual: Connection closed
× 2: Sends multiple CONTINUATION frames
-> The endpoint MUST accept multiple CONTINUATION frames.
- HTTP Message Exchanges
× 4: Sends a POST request with trailers
-> The endpoint MUST respond to the request.
Hypertext Transfer Protocol Version 2 (HTTP/2)
- HTTP Frames
4.2. Frame Size
× 3: Sends a large size HEADERS frame that exceeds the SETTINGS_MAX_FRAME_SIZE
-> The endpoint MUST respond with a connection error of type FRAME_SIZE_ERROR.
Expected: GOAWAY Frame (Error Code: FRAME_SIZE_ERROR)
Connection closed
Actual: DATA Frame (length:624, flags:0x01, stream_id:1)
- Streams and Multiplexing
5.1. Stream States
× 13: closed: Sends a CONTINUATION frame
-> The endpoint MUST treat this as a connection error of type STREAM_CLOSED.
Expected: GOAWAY Frame (Error Code: STREAM_CLOSED)
GOAWAY Frame (Error Code: PROTOCOL_ERROR)
Connection closed
Actual: RST_STREAM Frame (length:4, flags:0x00, stream_id:1)
- Frame Definitions
6.10. CONTINUATION
× 1: Sends multiple CONTINUATION frames preceded by a HEADERS frame
-> The endpoint must accept the frame.
× 4: Sends a CONTINUATION frame preceded by a HEADERS frame with END_HEADERS flag
-> The endpoint MUST respond with a connection error of type PROTOCOL_ERROR.
Expected: GOAWAY Frame (Error Code: PROTOCOL_ERROR)
Connection closed
8.1. HTTP Request/Response Exchange
8.1.2. HTTP Header Fields
8.1.2.6. Malformed Requests and Responses
× 1: Sends a HEADERS frame with the "content-length" header field which does not equal the DATA frame payload length
-> The endpoint MUST treat this as a stream error of type PROTOCOL_ERROR.
RST_STREAM Frame (Error Code: PROTOCOL_ERROR)
Connection closed
Actual: DATA Frame (length:182, flags:0x01, stream_id:1)
× 2: Sends a HEADERS frame with the "content-length" header field which does not equal the sum of the multiple DATA frames payload length
Connection closed
HPACK: Header Compression for HTTP/2
- Binary Format
6.3. Dynamic Table Size Update
× 1: Sends a dynamic table size update larger than the value of SETTINGS_HEADER_TABLE_SIZE
-> The endpoint MUST treat this as a decoding error.
Expected: GOAWAY Frame (Error Code: COMPRESSION_ERROR)
Connection closed
Finished in 18.9586 seconds
145 tests, 135 passed, 0 skipped, 10 failed
gaohd@host: ~/open_source/haproxy-1.8.17$ ./haproxy -vv
HA-Proxy version 1.8.17 2019/01/08
Copyright 2000-2019 Willy Tarreau willy@haproxy.org
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-format-truncation -Wno-null-dereference -Wno-unused-label
OPTIONS = USE_ZLIB=1 USE_OPENSSL=1 USE_PCRE=1 USE_TFO=1 USE_NS=1
Built with OpenSSL version : OpenSSL 1.1.0g 2 Nov 2017
Running on OpenSSL version : OpenSSL 1.1.0g 2 Nov 2017
haproxy config as follow:
ulimit-n 900
maxconn 400000
maxconnrate 0
nbproc 1
tune.http.cookielen 2048
tune.http.maxhdr 101
tune.bufsize 24576
maxconn 30000
backlog 8192
option clitcpka
frontend http
bind ipv4@0.0.0.0:80
log-format %ci:%cp\ [%t]\ %ft\ %b/%s\ %Tq/%Tw/%Tc/%Tr/%Tt\ %ST\ %B\ %CC\ %CS\ %tsc\ %ac/%fc/%bc/%sc/%rc\ %sq/%bq\ %hr\ %{+Q}r
rate-limit sessions 500000
capture request header Host len 256
capture request header User-Agent len 256
capture request header Referer len 256
capture request header Cookie len 256
capture request header X-Forwarded-For len 256
default_backend http_backend
frontend https
bind 0.0.0.0:443 ssl crt /usr/local/l7/resource/l7/crt/sina.pem alpn h2,http/1.1
default_backend https_backend
server myserver 10.6.130.69:80
server MyHttps 10.6.130.69:80 check inter 5000
