I tried the nc and netstat commands. No error with nc. netstat returns nothing.
/ # nc -l 127.0.0.1 34999
^Cpunt!
/ # sudo netstat -tulpen | grep 34999
sh: sudo: not found
/ # netstat -tulpen | grep 34999
/ #help
HAProxy info:
/ # haproxy -vv
HA-Proxy version 1.8.9-83616ec 2018/05/18
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -fno-strict-overflow -Wno-null-dereference -Wno-unused-label
OPTIONS = USE_ZLIB=1 USE_OPENSSL=1 USE_LUA=1 USE_PCRE=1
Built with OpenSSL version : OpenSSL 1.0.2o 27 Mar 2018
Running on OpenSSL version : OpenSSL 1.0.2o 27 Mar 2018
Built with PCRE version : 8.41 2017-07-05
Running on PCRE version : 8.41 2017-07-05
strace output (which I used CTRL-C to get out of):
/ # strace -tt haproxy -f /etc/haproxy/dynamic/haproxy.cfg -d -L ip-10-10-44-9
18:30:05.997183 execve("/usr/local/sbin/haproxy", ["haproxy", "-f", "/etc/haproxy/dynamic/haproxy.cfg", "-d", "-L", "ip-10-10-44-9"], 0x7ffcbed72c10 /* 77 vars */) = 0
18:30:05.997599 arch_prctl(ARCH_SET_FS, 0x7f1481effb88) = 0
18:30:05.997631 set_tid_address(0x7f1481effbc0) = 35
18:30:05.997677 open("/etc/ld-musl-x86_64.path", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
18:30:05.997720 open("/lib/libz.so.1", O_RDONLY|O_CLOEXEC) = 3
18:30:05.997758 fcntl(3, F_SETFD, FD_CLOEXEC) = 0
18:30:05.997789 fstat(3, {st_mode=S_IFREG|0755, st_size=91952, ...}) = 0
18:30:05.997829 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\260!\0\0\0\0\0\0"..., 960) = 960
18:30:05.997866 mmap(NULL, 2191360, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x7f1481a5d000
18:30:05.997904 mmap(0x7f1481c72000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x15000) = 0x7f1481c72000
18:30:05.997953 close(3) = 0
18:30:05.997983 open("/lib/libssl.so.1.0.0", O_RDONLY|O_CLOEXEC) = 3
18:30:05.998020 fcntl(3, F_SETFD, FD_CLOEXEC) = 0
18:30:05.998088 fstat(3, {st_mode=S_IFREG|0555, st_size=429112, ...}) = 0
18:30:05.998136 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\230\221\1\0\0\0\0\0"..., 960) = 960
18:30:05.998196 mmap(NULL, 2527232, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x7f14817f4000
18:30:05.998245 mmap(0x7f1481a52000, 45056, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x5e000) = 0x7f1481a52000
18:30:05.998306 close(3) = 0
18:30:05.998340 open("/lib/libcrypto.so.1.0.0", O_RDONLY|O_CLOEXEC) = 3
18:30:05.998496 fcntl(3, F_SETFD, FD_CLOEXEC) = 0
18:30:05.998559 fstat(3, {st_mode=S_IFREG|0555, st_size=2213448, ...}) = 0
18:30:05.998652 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0\0z\6\0\0\0\0\0"..., 960) = 960
18:30:05.998715 mmap(NULL, 4325376, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x7f14813d4000
18:30:05.998883 mmap(0x7f14817c9000, 176128, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x1f5000) = 0x7f14817c9000
18:30:05.998987 mmap(0x7f14817f0000, 16384, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED|MAP_ANONYMOUS, -1, 0) = 0x7f14817f0000
18:30:05.999126 close(3) = 0
18:30:05.999229 open("/lib/liblua-5.3.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
18:30:05.999364 open("/usr/local/lib/liblua-5.3.so.0", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
18:30:05.999475 open("/usr/lib/liblua-5.3.so.0", O_RDONLY|O_CLOEXEC) = 3
18:30:05.999571 fcntl(3, F_SETFD, FD_CLOEXEC) = 0
18:30:05.999714 fstat(3, {st_mode=S_IFREG|0644, st_size=198288, ...}) = 0
18:30:05.999820 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0`s\0\0\0\0\0\0"..., 960) = 960
18:30:05.999913 mmap(NULL, 2297856, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x7f14811a3000
18:30:06.000030 mmap(0x7f14813d1000, 12288, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x2e000) = 0x7f14813d1000
18:30:06.000169 close(3) = 0
18:30:06.000247 open("/lib/libpcre.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
18:30:06.000362 open("/usr/local/lib/libpcre.so.1", O_RDONLY|O_CLOEXEC) = -1 ENOENT (No such file or directory)
18:30:06.000443 open("/usr/lib/libpcre.so.1", O_RDONLY|O_CLOEXEC) = 3
18:30:06.000554 fcntl(3, F_SETFD, FD_CLOEXEC) = 0
18:30:06.000626 fstat(3, {st_mode=S_IFREG|0755, st_size=370360, ...}) = 0
18:30:06.000708 read(3, "\177ELF\2\1\1\0\0\0\0\0\0\0\0\0\3\0>\0\1\0\0\0@\24\0\0\0\0\0\0"..., 960) = 960
18:30:06.000810 mmap(NULL, 2469888, PROT_READ|PROT_EXEC, MAP_PRIVATE, 3, 0) = 0x7f1480f48000
18:30:06.000886 mmap(0x7f14811a1000, 8192, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_FIXED, 3, 0x59000) = 0x7f14811a1000
18:30:06.001070 close(3) = 0
18:30:06.001222 mprotect(0x7f1481c72000, 4096, PROT_READ) = 0
18:30:06.001519 mprotect(0x7f1481a52000, 20480, PROT_READ) = 0
18:30:06.001850 mprotect(0x7f14817c9000, 114688, PROT_READ) = 0
18:30:06.001975 mprotect(0x7f14813d1000, 8192, PROT_READ) = 0
18:30:06.002108 mprotect(0x7f14811a1000, 4096, PROT_READ) = 0
18:30:06.002191 mprotect(0x7f1481efc000, 4096, PROT_READ) = 0
18:30:06.002473 mprotect(0x5642c3fc7000, 16384, PROT_READ) = 0
18:30:06.002559 brk(NULL) = 0x5642c5fdd000
18:30:06.002677 brk(0x5642c5fe0000) = 0x5642c5fe0000
18:30:06.002747 arch_prctl(ARCH_SET_FS, 0x5642c5fdf2c0) = 0
18:30:06.002865 set_tid_address(0x5642c5fdf2f8) = 35
18:30:06.003293 brk(0x5642c5fe1000) = 0x5642c5fe1000
18:30:06.003420 brk(0x5642c5fe2000) = 0x5642c5fe2000
18:30:06.003530 brk(0x5642c5fe3000) = 0x5642c5fe3000
18:30:06.003636 brk(0x5642c5fe4000) = 0x5642c5fe4000
18:30:06.003771 brk(0x5642c5fe5000) = 0x5642c5fe5000
18:30:06.003868 brk(0x5642c5fe6000) = 0x5642c5fe6000
18:30:06.003968 brk(0x5642c5fe8000) = 0x5642c5fe8000
18:30:06.004126 brk(0x5642c5fe9000) = 0x5642c5fe9000
18:30:06.004232 brk(0x5642c5fea000) = 0x5642c5fea000
18:30:06.004319 brk(0x5642c5feb000) = 0x5642c5feb000
18:30:06.004470 brk(0x5642c5fec000) = 0x5642c5fec000
18:30:06.004630 brk(0x5642c5ff1000) = 0x5642c5ff1000
18:30:06.004757 brk(0x5642c5ff6000) = 0x5642c5ff6000
18:30:06.004841 brk(0x5642c5ffb000) = 0x5642c5ffb000
18:30:06.004945 uname({sysname="Linux", nodename="haproxy-router-64cfd4cf7c-f2pnj", ...}) = 0
18:30:06.005046 open("/etc/localtime", O_RDONLY|O_NONBLOCK|O_CLOEXEC) = 3
18:30:06.005148 fstat(3, {st_mode=S_IFREG|0644, st_size=127, ...}) = 0
18:30:06.005271 mmap(NULL, 127, PROT_READ, MAP_SHARED, 3, 0) = 0x7f1481efb000
18:30:06.005416 close(3) = 0
18:30:06.005503 clock_gettime(CLOCK_REALTIME, {tv_sec=1529692206, tv_nsec=5529198}) = 0
18:30:06.005598 getpid() = 35
18:30:06.005678 rt_sigprocmask(SIG_SETMASK, [USR2], NULL, 8) = 0
18:30:06.005860 clock_gettime(CLOCK_REALTIME, {tv_sec=1529692206, tv_nsec=5901721}) = 0
18:30:06.006018 brk(0x5642c5ffc000) = 0x5642c5ffc000
18:30:06.006127 brk(0x5642c5ffd000) = 0x5642c5ffd000
18:30:06.006227 brk(0x5642c5ffe000) = 0x5642c5ffe000
18:30:06.006353 brk(0x5642c5fff000) = 0x5642c5fff000
18:30:06.006485 brk(0x5642c6000000) = 0x5642c6000000
18:30:06.006605 brk(0x5642c6001000) = 0x5642c6001000
18:30:06.006700 brk(0x5642c6003000) = 0x5642c6003000
18:30:06.006839 brk(0x5642c6004000) = 0x5642c6004000
18:30:06.006954 brk(0x5642c6005000) = 0x5642c6005000
18:30:06.007052 brk(0x5642c6006000) = 0x5642c6006000
18:30:06.007139 brk(0x5642c6007000) = 0x5642c6007000
18:30:06.007200 brk(0x5642c6009000) = 0x5642c6009000
18:30:06.007316 brk(0x5642c600c000) = 0x5642c600c000
18:30:06.007449 brk(0x5642c600f000) = 0x5642c600f000
18:30:06.007621 brk(0x5642c6014000) = 0x5642c6014000
18:30:06.007830 brk(0x5642c6015000) = 0x5642c6015000
18:30:06.007970 brk(0x5642c6016000) = 0x5642c6016000
18:30:06.008084 getpid() = 35
18:30:06.008148 getpid() = 35
18:30:06.008233 open("/dev/urandom", O_RDONLY|O_NOCTTY|O_NONBLOCK) = 3
18:30:06.008325 fstat(3, {st_mode=S_IFCHR|0666, st_rdev=makedev(1, 9), ...}) = 0
18:30:06.008414 poll([{fd=3, events=POLLIN}], 1, 10) = 1 ([{fd=3, revents=POLLIN}])
18:30:06.008513 read(3, "\220K&\277\342gf\303\325\214\342\201\367\223\360\37\325h}\30\372\277cU\212\33\332\353%\205\346\36", 32) = 32
18:30:06.008579 close(3) = 0
18:30:06.008670 getuid() = 0
18:30:06.008778 clock_gettime(CLOCK_REALTIME, {tv_sec=1529692206, tv_nsec=8800714}) = 0
18:30:06.008904 brk(0x5642c6017000) = 0x5642c6017000
18:30:06.009045 brk(0x5642c6019000) = 0x5642c6019000
18:30:06.009186 getpid() = 35
18:30:06.009255 getpid() = 35
18:30:06.009316 getpid() = 35
18:30:06.009369 getpid() = 35
18:30:06.009479 stat("/etc/haproxy/dynamic/haproxy.cfg", {st_mode=S_IFREG|0644, st_size=1510, ...}) = 0
18:30:06.009594 open("/etc/haproxy/dynamic/haproxy.cfg", O_RDONLY) = 3
18:30:06.009674 readv(3, [{iov_base="", iov_len=0}, {iov_base="global\n log 127.0.0.1:9515 loca"..., iov_len=1024}], 2) = 1024
18:30:06.009798 brk(0x5642c601b000) = 0x5642c601b000
18:30:06.009941 open("/etc/haproxy/static/errors/400.http", O_RDONLY) = 4
18:30:06.010072 fstat(4, {st_mode=S_IFREG|0644, st_size=183, ...}) = 0
18:30:06.010177 read(4, "HTTP/1.0 400 Bad request\nCache-C"..., 183) = 183
18:30:06.010332 close(4) = 0
18:30:06.010415 open("/etc/haproxy/static/errors/403.http", O_RDONLY) = 4
18:30:06.010552 fstat(4, {st_mode=S_IFREG|0644, st_size=184, ...}) = 0
18:30:06.010687 read(4, "HTTP/1.0 403 Forbidden\nCache-Con"..., 184) = 184
18:30:06.010792 close(4) = 0
18:30:06.010869 open("/etc/haproxy/static/errors/408.http", O_RDONLY) = 4
18:30:06.010955 fstat(4, {st_mode=S_IFREG|0644, st_size=208, ...}) = 0
18:30:06.011094 read(4, "HTTP/1.0 408 Request Time-out\nCa"..., 208) = 208
18:30:06.011188 close(4) = 0
18:30:06.011302 open("/etc/haproxy/static/errors/500.http", O_RDONLY) = 4
18:30:06.011414 fstat(4, {st_mode=S_IFREG|0644, st_size=181, ...}) = 0
18:30:06.011487 read(4, "HTTP/1.0 500 Server Error\nCache-"..., 181) = 181
18:30:06.011621 close(4) = 0
18:30:06.011693 open("/etc/haproxy/static/errors/502.http", O_RDONLY) = 4
18:30:06.011784 fstat(4, {st_mode=S_IFREG|0644, st_size=200, ...}) = 0
18:30:06.011942 read(4, "HTTP/1.0 502 Bad Gateway\nCache-C"..., 200) = 200
18:30:06.012082 close(4) = 0
18:30:06.012158 open("/etc/haproxy/static/errors/503.http", O_RDONLY) = 4
18:30:06.012242 fstat(4, {st_mode=S_IFREG|0644, st_size=208, ...}) = 0
18:30:06.012325 read(4, "HTTP/1.0 503 Service Unavailable"..., 208) = 208
18:30:06.012397 close(4) = 0
18:30:06.012537 readv(3, [{iov_base="", iov_len=0}, {iov_base=" 504 /etc/haproxy/static/errors/"..., iov_len=1024}], 2) = 486
18:30:06.012629 open("/etc/haproxy/static/errors/504.http", O_RDONLY) = 4
18:30:06.012711 fstat(4, {st_mode=S_IFREG|0644, st_size=190, ...}) = 0
18:30:06.012855 read(4, "HTTP/1.0 504 Gateway Time-out\nCa"..., 190) = 190
18:30:06.012965 close(4) = 0
18:30:06.013039 brk(0x5642c601d000) = 0x5642c601d000
18:30:06.013129 brk(0x5642c601e000) = 0x5642c601e000
18:30:06.013265 brk(0x5642c6020000) = 0x5642c6020000
18:30:06.013349 brk(0x5642c6022000) = 0x5642c6022000
18:30:06.013523 readv(3, [{iov_base="", iov_len=0}, {iov_base="", iov_len=1024}], 2) = 0
18:30:06.013692 close(3) = 0
18:30:06.013770 clock_gettime(CLOCK_REALTIME, {tv_sec=1529692206, tv_nsec=13792909}) = 0
18:30:06.013907 brk(0x5642c6033000) = 0x5642c6033000
18:30:06.013976 brk(0x5642c6044000) = 0x5642c6044000
18:30:06.014059 brk(0x5642c6055000) = 0x5642c6055000
18:30:06.014199 brk(0x5642c6066000) = 0x5642c6066000
18:30:06.014285 brk(0x5642c6077000) = 0x5642c6077000
18:30:06.014424 brk(0x5642c6088000) = 0x5642c6088000
18:30:06.014523 writev(2, [{iov_base="", iov_len=0}, {iov_base="Available polling systems :\n", iov_len=28}], 2Available polling systems :
) = 28
18:30:06.014681 writev(2, [{iov_base=" epoll : ", iov_len=14}, {iov_base=NULL, iov_len=0}], 2 epoll : ) = 14
18:30:06.014858 writev(2, [{iov_base="pref=300, ", iov_len=10}, {iov_base=NULL, iov_len=0}], 2pref=300, ) = 10
18:30:06.014978 epoll_create1(0) = 3
18:30:06.015096 close(3) = 0
18:30:06.015163 writev(2, [{iov_base="", iov_len=0}, {iov_base=" test result OK", iov_len=15}], 2 test result OK) = 15
18:30:06.015303 writev(2, [{iov_base="", iov_len=0}, {iov_base="\n", iov_len=1}], 2
) = 1
18:30:06.015402 writev(2, [{iov_base=" poll : ", iov_len=14}, {iov_base=NULL, iov_len=0}], 2 poll : ) = 14
18:30:06.015490 writev(2, [{iov_base="pref=200, ", iov_len=10}, {iov_base=NULL, iov_len=0}], 2pref=200, ) = 10
18:30:06.015632 writev(2, [{iov_base="", iov_len=0}, {iov_base=" test result OK", iov_len=15}], 2 test result OK) = 15
18:30:06.015743 writev(2, [{iov_base="", iov_len=0}, {iov_base="\n", iov_len=1}], 2
) = 1
18:30:06.015923 writev(2, [{iov_base=" select : ", iov_len=14}, {iov_base=NULL, iov_len=0}], 2 select : ) = 14
18:30:06.016081 writev(2, [{iov_base="pref=150, ", iov_len=10}, {iov_base=NULL, iov_len=0}], 2pref=150, ) = 10
18:30:06.016188 writev(2, [{iov_base="", iov_len=0}, {iov_base=" test result FAILED", iov_len=19}], 2 test result FAILED) = 19
18:30:06.016281 writev(2, [{iov_base="", iov_len=0}, {iov_base="\n", iov_len=1}], 2
) = 1
18:30:06.016391 writev(2, [{iov_base="Total: 3 (2 usable), will use ep"..., iov_len=37}, {iov_base=NULL, iov_len=0}], 2Total: 3 (2 usable), will use epoll.
) = 37
18:30:06.016535 writev(2, [{iov_base="", iov_len=0}, {iov_base="\n", iov_len=1}], 2
) = 1
18:30:06.016678 writev(2, [{iov_base="", iov_len=0}, {iov_base="Available filters :\n", iov_len=20}], 2Available filters :
) = 20
18:30:06.016798 writev(2, [{iov_base="\t[SPOE] spoe\n", iov_len=13}, {iov_base=NULL, iov_len=0}], 2 [SPOE] spoe
) = 13
18:30:06.016896 writev(2, [{iov_base="\t[COMP] compression\n", iov_len=20}, {iov_base=NULL, iov_len=0}], 2 [COMP] compression
) = 20
18:30:06.017056 writev(2, [{iov_base="\t[TRACE] trace\n", iov_len=15}, {iov_base=NULL, iov_len=0}], 2 [TRACE] trace
) = 15
18:30:06.017161 mmap(NULL, 1028096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f1481e00000
18:30:06.017282 mmap(NULL, 258048, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0x7f1481dc1000
18:30:06.017378 brk(0x5642c6098000) = 0x5642c6098000
18:30:06.017976 epoll_create1(0) = 3
18:30:06.018040 ioctl(1, TIOCGWINSZ, {ws_row=60, ws_col=135, ws_xpixel=0, ws_ypixel=0}) = 0
18:30:06.018117 writev(1, [{iov_base="Using epoll", iov_len=11}, {iov_base="() as the polling mechanism.\n", iov_len=29}], 2Using epoll() as the polling mechanism.
) = 40
18:30:06.018263 rt_sigprocmask(SIG_UNBLOCK, [RT_1 RT_2], NULL, 8) = 0
18:30:06.018359 rt_sigaction(SIGQUIT, {sa_handler=0x5642c3d7bcd0, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f1481cba0ea}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
18:30:06.018463 rt_sigaction(SIGUSR1, {sa_handler=0x5642c3d7bcd0, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f1481cba0ea}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
18:30:06.018565 rt_sigaction(SIGHUP, {sa_handler=0x5642c3d7bcd0, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f1481cba0ea}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
18:30:06.018779 rt_sigaction(SIGUSR2, {sa_handler=SIG_IGN, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f1481cba0ea}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
18:30:06.018892 rt_sigaction(SIGPIPE, {sa_handler=SIG_IGN, sa_mask=[], sa_flags=SA_RESTORER|SA_RESTART, sa_restorer=0x7f1481cba0ea}, {sa_handler=SIG_DFL, sa_mask=[], sa_flags=0}, 8) = 0
18:30:06.019021 rt_sigprocmask(SIG_BLOCK, ~[RTMIN RT_1 RT_2], [USR2], 8) = 0
18:30:06.019154 rt_sigprocmask(SIG_BLOCK, ~[], NULL, 8) = 0
18:30:06.019253 prlimit64(0, RLIMIT_NOFILE, {rlim_cur=16035, rlim_max=16035}, NULL) = 0
18:30:06.019330 futex(0x7f1481f000a0, FUTEX_WAKE_PRIVATE, 2147483647) = 0
18:30:06.019430 rt_sigprocmask(SIG_SETMASK, [USR2], NULL, 8) = 0
18:30:06.019503 unlink("/var/run/haproxy.sock.35.tmp") = -1 ENOENT (No such file or directory)
18:30:06.019652 unlink("/var/run/haproxy.sock.35.bak") = -1 ENOENT (No such file or directory)
18:30:06.019742 link("/var/run/haproxy.sock", "/var/run/haproxy.sock.35.bak") = 0
18:30:06.019849 socket(AF_UNIX, SOCK_STREAM, 0) = 4
18:30:06.019992 fcntl(4, F_SETFL, O_RDONLY|O_NONBLOCK) = 0
18:30:06.020081 bind(4, {sa_family=AF_UNIX, sun_path="/var/run/haproxy.sock.35.tmp"}, 110) = 0
18:30:06.020270 chmod("/var/run/haproxy.sock.35.tmp", 0600) = 0
18:30:06.020357 getsockopt(4, SOL_SOCKET, SO_ACCEPTCONN, [0], [4]) = 0
18:30:06.020440 listen(4, 10) = 0
18:30:06.020560 rename("/var/run/haproxy.sock.35.tmp", "/var/run/haproxy.sock") = 0
18:30:06.020669 unlink("/var/run/haproxy.sock.35.bak") = 0
18:30:06.020848 socket(AF_INET, SOCK_STREAM, IPPROTO_TCP) = 5
18:30:06.020963 getsockopt(5, SOL_TCP, TCP_MAXSEG, [536], [4]) = 0
18:30:06.021107 close(5) = 0
18:30:06.021203 socket(AF_INET6, SOCK_STREAM, IPPROTO_TCP) = 5
18:30:06.021412 getsockopt(5, SOL_TCP, TCP_MAXSEG, [536], [4]) = 0
18:30:06.021512 close(5) = 0
18:30:06.021577 socket(AF_INET, SOCK_STREAM, IPPROTO_TCP) = 5
18:30:06.021722 fcntl(5, F_SETFL, O_RDONLY|O_NONBLOCK) = 0
18:30:06.021797 setsockopt(5, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
18:30:06.021950 getsockopt(5, SOL_SOCKET, SO_LINGER, {l_onoff=0, l_linger=0}, [8]) = 0
18:30:06.022044 setsockopt(5, SOL_SOCKET, SO_LINGER, {l_onoff=0, l_linger=0}, 8) = 0
18:30:06.022130 setsockopt(5, SOL_SOCKET, SO_REUSEPORT, [1], 4) = 0
18:30:06.022214 setsockopt(5, SOL_TCP, TCP_USER_TIMEOUT, [0], 4) = 0
18:30:06.022376 setsockopt(5, SOL_TCP, TCP_DEFER_ACCEPT, [0], 4) = 0
18:30:06.022511 getsockopt(5, SOL_TCP, TCP_FASTOPEN, [0], [4]) = 0
18:30:06.022604 bind(5, {sa_family=AF_INET, sin_port=htons(35000), sin_addr=inet_addr("0.0.0.0")}, 16) = 0
18:30:06.022745 getsockopt(5, SOL_SOCKET, SO_ACCEPTCONN, [0], [4]) = 0
18:30:06.022841 listen(5, 8000) = 0
18:30:06.022960 setsockopt(5, SOL_TCP, TCP_QUICKACK, [0], 4) = 0
18:30:06.023046 getpid() = 35
18:30:06.023175 getpid() = 35
18:30:06.023235 socket(AF_INET, SOCK_DGRAM, IPPROTO_UDP) = 6
18:30:06.023362 setsockopt(6, SOL_SOCKET, SO_RCVBUF, [0], 4) = 0
18:30:06.023460 shutdown(6, SHUT_RD) = -1 ENOTCONN (Socket not connected)
18:30:06.023531 fcntl(6, F_GETFD) = 0
18:30:06.023660 fcntl(6, F_SETFD, FD_CLOEXEC) = 0
18:30:06.023729 sendmsg(6, {msg_name={sa_family=AF_INET, sin_port=htons(9515), sin_addr=inet_addr("127.0.0.1")}, msg_namelen=16, msg_iov=[{iov_base="<133>Jun 22 18:30:06 haproxy-rou"..., iov_len=53}, {iov_base="haproxy", iov_len=7}, {iov_base="[", iov_len=1}, {iov_base="35", iov_len=2}, {iov_base="]: ", iov_len=3}, {iov_base="", iov_len=0}, {iov_base="Proxy stats started.", iov_len=20}, {iov_base="\n", iov_len=1}], msg_iovlen=8, msg_controllen=0, msg_flags=0}, MSG_DONTWAIT|MSG_NOSIGNAL) = 87
18:30:06.028986 sendmsg(6, {msg_name={sa_family=AF_INET, sin_port=htons(9514), sin_addr=inet_addr("127.0.0.1")}, msg_namelen=16, msg_iov=[{iov_base="<141>Jun 22 18:30:06 haproxy-rou"..., iov_len=53}, {iov_base="haproxy", iov_len=7}, {iov_base="[", iov_len=1}, {iov_base="35", iov_len=2}, {iov_base="]: ", iov_len=3}, {iov_base="", iov_len=0}, {iov_base="Proxy stats started.", iov_len=20}, {iov_base="\n", iov_len=1}], msg_iovlen=8, msg_controllen=0, msg_flags=0}, MSG_DONTWAIT|MSG_NOSIGNAL) = 87
18:30:06.029861 socket(AF_INET, SOCK_STREAM, IPPROTO_TCP) = 7
18:30:06.030191 fcntl(7, F_SETFL, O_RDONLY|O_NONBLOCK) = 0
18:30:06.030289 setsockopt(7, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
18:30:06.030423 getsockopt(7, SOL_SOCKET, SO_LINGER, {l_onoff=0, l_linger=0}, [8]) = 0
18:30:06.030574 setsockopt(7, SOL_SOCKET, SO_LINGER, {l_onoff=0, l_linger=0}, 8) = 0
18:30:06.030742 setsockopt(7, SOL_SOCKET, SO_REUSEPORT, [1], 4) = 0
18:30:06.030905 setsockopt(7, SOL_TCP, TCP_USER_TIMEOUT, [0], 4) = 0
18:30:06.031058 setsockopt(7, SOL_TCP, TCP_DEFER_ACCEPT, [0], 4) = 0
18:30:06.031268 getsockopt(7, SOL_TCP, TCP_FASTOPEN, [0], [4]) = 0
18:30:06.031442 bind(7, {sa_family=AF_INET, sin_port=htons(35001), sin_addr=inet_addr("0.0.0.0")}, 16) = 0
18:30:06.031596 getsockopt(7, SOL_SOCKET, SO_ACCEPTCONN, [0], [4]) = 0
18:30:06.031721 listen(7, 8000) = 0
18:30:06.031885 setsockopt(7, SOL_TCP, TCP_QUICKACK, [0], 4) = 0
18:30:06.032033 getpid() = 35
18:30:06.032155 sendmsg(6, {msg_name={sa_family=AF_INET, sin_port=htons(9515), sin_addr=inet_addr("127.0.0.1")}, msg_namelen=16, msg_iov=[{iov_base="<133>Jun 22 18:30:06 haproxy-rou"..., iov_len=53}, {iov_base="haproxy", iov_len=7}, {iov_base="[", iov_len=1}, {iov_base="35", iov_len=2}, {iov_base="]: ", iov_len=3}, {iov_base="", iov_len=0}, {iov_base="Proxy http started.", iov_len=19}, {iov_base="\n", iov_len=1}], msg_iovlen=8, msg_controllen=0, msg_flags=0}, MSG_DONTWAIT|MSG_NOSIGNAL) = 86
18:30:06.032758 sendmsg(6, {msg_name={sa_family=AF_INET, sin_port=htons(9514), sin_addr=inet_addr("127.0.0.1")}, msg_namelen=16, msg_iov=[{iov_base="<141>Jun 22 18:30:06 haproxy-rou"..., iov_len=53}, {iov_base="haproxy", iov_len=7}, {iov_base="[", iov_len=1}, {iov_base="35", iov_len=2}, {iov_base="]: ", iov_len=3}, {iov_base="", iov_len=0}, {iov_base="Proxy http started.", iov_len=19}, {iov_base="\n", iov_len=1}], msg_iovlen=8, msg_controllen=0, msg_flags=0}, MSG_DONTWAIT|MSG_NOSIGNAL) = 86
18:30:06.036063 socket(AF_INET, SOCK_STREAM, IPPROTO_TCP) = 8
18:30:06.036214 fcntl(8, F_SETFL, O_RDONLY|O_NONBLOCK) = 0
18:30:06.036348 setsockopt(8, SOL_SOCKET, SO_REUSEADDR, [1], 4) = 0
18:30:06.036568 getsockopt(8, SOL_SOCKET, SO_LINGER, {l_onoff=0, l_linger=0}, [8]) = 0
18:30:06.036702 setsockopt(8, SOL_SOCKET, SO_LINGER, {l_onoff=0, l_linger=0}, 8) = 0
18:30:06.036812 setsockopt(8, SOL_SOCKET, SO_REUSEPORT, [1], 4) = 0
18:30:06.036967 setsockopt(8, SOL_TCP, TCP_USER_TIMEOUT, [0], 4) = 0
18:30:06.037087 setsockopt(8, SOL_TCP, TCP_DEFER_ACCEPT, [0], 4) = 0
18:30:06.037276 getsockopt(8, SOL_TCP, TCP_FASTOPEN, [0], [4]) = 0
18:30:06.037438 bind(8, {sa_family=AF_INET, sin_port=htons(34999), sin_addr=inet_addr("10.10.44.9")}, 16) = -1 EADDRNOTAVAIL (Address not available)
18:30:06.037654 close(8) = 0
18:30:06.037743 getpid() = 35
18:30:06.037880 writev(2, [{iov_base="[ALERT] 172/183006 (35) : [hapro"..., iov_len=45}, {iov_base=NULL, iov_len=0}], 2[ALERT] 172/183006 (35) : [haproxy.main()] .
) = 45
18:30:06.038034 getpid() = 35
18:30:06.038132 writev(2, [{iov_base="[ALERT] 172/183006 (35) : ", iov_len=26}, {iov_base="[haproxy.main()] Some protocols "..., iov_len=74}], 2[ALERT] 172/183006 (35) : [haproxy.main()] Some protocols failed to start their listeners! Exiting.
) = 100
18:30:06.038308 writev(2, [{iov_base="", iov_len=0}, {iov_base=NULL, iov_len=0}], 2) = 0
18:30:06.038485 close(5) = 0
18:30:06.038556 close(7) = 0
18:30:06.038726 close(4) = 0
18:30:06.038912 exit_group(1) = ?
18:30:06.039288 +++ exited with 1 +++
I should note that this is in an alpine-linux container running in Kubernetes on top of an Ubuntu 14.04 EC2 instance.
