Since a long time I’m using haproxy (as a package on pfsense, HAProxy version 2.4.9-f8dcd9f, released 2021/11/24) to handle incoming requests to my homelab environment. Recently I upgraded Tomcat to version 10 on one of by backends and also upgraded a few server running IIS from W2K12 to W2K19.
Since that moment I noticed that some requests were aborted. After doing some more investigation it looks like to problem is related to the combination of http/2 on the backend (which was introduced as a “default” after upgrade to Tomcat10 and W2K19) and using the transparant client ip mode in haproxy.
So I always used the following settings for one of my applations (reduced the config for readability to only the frontend and backend I’m currently testing with):
maxconn 100
log srv-nas-01.home.mydomain.com local0 info
gid 80
nbproc 1
nbthread 1
hard-stop-after 15m
chroot /tmp/haproxy_chroot
log-send-hostname srv-fw-01-haproxy
listen HAProxyLocalStats
stats admin if TRUE
stats show-legends
timeout client 5000
timeout server 5000
frontend SharedFrontEnd-merged
bind 192.168.1.1:443 name 192.168.1.1:443
bind 192.168.7.2:443 name 192.168.7.2:443
timeout client 30000
acl host_login req.ssl_sni -i login.mydomain.com
use_backend OTDS_ipv4 if host_login
backend OTDS_ipv4
id 10119
timeout connect 30000
timeout server 30000
source ipv4@ usesrc clientip
server srv-otds-01_https 192.168.48.10:443 id 10121
When I load a page containing quite a lot of javascript files and other files, and caching is disabled so I force the browser to load all requests, let’s day 80% of the requests succeed.
On a reload (with cache disabled) I see same behaviour, althought not exactly the same requests will fail, most times it are almost the same files. Opening these files individually is no problem. In the Apache log I see the requests are handled correctly.
If I remove the setting UpgradeProtocol from the Tomcat config, only 1 request out of about 300 requests for this page fails. Also not always the same.
When I remove the line source ipv4@ usesrc clientip from the backend configuration it works without any problem. It then runs on http/2.0 according to the Tomcat access logs.
Initially my assumption was this only happens on my Tomcat server, but now I see common behavior on my IIS server as well and I guess since the update to W2K19 IIS is also working with http/2.
I’m a bit lost in what is/could be causing this issue. Of course I could just disable the userc clientip setting, but I like this as it gives me the source ips and it should work, isn’t it?
Any suggestions/ideas?
