Hi all,
I have a problem with HAProxy configuration. Because my HAProxy isn’t in the same data center as my web server, I have working configuration to connect www-backend to my webserver’s HTTPS port. It all works just fine.
Well… Almost.
Today I tried to upload a file (250 kB) using a <form> and I got HTTP 413 Request entity too large. Checking the Apache server log, I’ve found two messages:
AH02018: request body exceeds maximum size (131072) for SSL buffer, referer: https://my.website.com/page
and
AH02257: could not buffer message body to allow SSL renegotiation to proceed, referer: https://my.website.com/page
I’ve done some investigation, found couple of old articles at stackoverflow, all recommending setting Apache’s SSLRenegBufferSize to something bigger. I don’t want to go that way.
I’ve tried to upload the file directly to webserver (bypassing HAProxy) and it works just fine.
Changing my server definition in www-backend from:
server server1 1.2.3.4:443 check ssl verify none
to
server server1 1.2.3.4:80 check
resolved the issue and I was able to upload the file while being connected through HAProxy.
However, I don’t like the possibility of a MITM attack between HAProxy and my www servers (however unlikely it is).
Is there a way to prevent the SSL renegotiation when user submits the form and uploads the file to the server?
My haproxy.cfg:
log /dev/log local0 notice
ssl-default-server-ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256
timeout connect 15000
frontend http-in
bind :80
bind *:443 ssl crt /etc/haproxy/certificate.pem
# Redirect if HTTPS is *not* used
# Test URI to see if its a letsencrypt request
default_backend www-backend
backend www-backend
stick-table type ip size 200k expire 30m
stick on src
default-server inter 1s
#server server1 1.2.3.4:443 check ssl verify none
Any help is much appreciated!
