SSL Termination
I’m want to configure SSL Termination with version 1.6.
I have the error but i don’t know where.
I don’t know where can i see the log.
Thanks in advance.
My configuration file is :
frontend www-http
option httpclose
acl localACL hdr_dom(host) -i localhost
use_backend mytravelBackend if localACL
default_backend defaultBackendServer
frontend www-https
bind *:21 ssl crt /etc/ssl/certs/certificate.pem
mode https
option httpclose
use_backend localBackend if localACL
balance source
server SRV-WEB-1 192.168.2.13:80 check
server SRV-WEB-2 192.168.2.14:80 check
balance source
acl no_redir url_beg /new/new
reqirep ^([^\ :])\ /(.) \1\ /new/new\2 if !no_redir
HTTP is port 443, not 21. Also, its “mode http”, there is no “mode https” even though you are terminating ssl.
I assume this configuration is completely invalid, and haproxy rejects it. You will see in what line the configuration error is, when starting haproxy.
Yes the configuration was totally invalid.
Now i have this error message : unable to load SSL private key from
First of all, i can’t see the link but the link that i provided from pem file is correct.
And i don’t if it’s because my private key has the passphrase ? And if it’s it, how can i do ?
Are you sure the pem file contains both the certificate and the key in that sequence?
Like:
cat cert.pem key.pem > certificate.pem
Yesi had put it !
The used command was:
cat public.crt >> certificate.pem
cat private.key >> certificate.pem
cat intermediate.crt >> certificate.pem
I don’t know if is good.
Only if certificate.pem was guaranteed to be empty before this commands.
That’s why you don’t do it your way, but:
cat public.crt private.key intermediate.crt >certificate.pem
Ok!
I have change the order to public intermediate and private.
Haprocy seems recognize it.
I have the following instruction into the error log : Enter PEM pass phrase:
I don’t know how to enter it
Don’t use an encrypted private key, if you want haproxy to start on its own.
It’s OK!
It’s function
