Hey I am new to haproxy.
I got a working proxy on port 80 to 8080, and I want to replace port 80 to 443 and use a specific wildcard certificate that is not lets encrypt.
I want to have a specific HTTPS URL - that does not have an apache virtual host.
My example https://publicname.com that resolve it self into privatename
My backend is then port 8080.
The error message is
[ALERT] 340/111702 (61859) : parsing [/tmp//2018-12-07.10:17:01.cfg:41] : ‘bind realpublic ip :443’ : unable to load SSL private key from PEM file ‘/etc/ssl/certs/newfile4.crt.pem’. [ALERT] 340/111702 (61859) : Error(s) found in configuration file : /tmp//2018-12-07.10:17:01.cfg [ALERT] 340/111702 (61859) : Fatal errors found in configuration.
My configuration is
frontend http-in
bind real.public.ip.yes:443 ssl crt /etc/ssl/certs/newfile4.crt.pem
acl fronturl hdr(host) eq publicname.com
use_backend test-backend if fronturl
http-request set-header Host privatename.publicdomain.com (This have an apache virtualhost and is responding perfectly)
server node1 10.0.0.100:8080
Eventually I will add “round-robin” to backend and add more serveres once the front config is working.
Can anyone help?
