Gayathri Manoj <gayathri.annur@gmail.com> Tue, Mar 5, 3:50 PM (1 day ago)
to haproxy
Hi All,
I am getting the below error while loading haproxy service.
‘bind :::6971’ : unable to load SSL private key into SSL Context ‘/usr/xxx/yyy/HAProxy.pem.rsa’.
Command used for starting the haproxy service :
haproxy -D -f /usr/local/conf/haproxy.conf
Conf file contains many port and if i comment this particular port then the service is starting.
Tested the below things:
Certificate and its key match
Executed the test in SELinux permissive mode
Order changed for HAProxy_truststore.pem.
Bind command :
bind :::6971 ssl crt /usr/xxx/yyy/HAProxy.pem ca-file /usr/xxx/yyy/HAProxy_truststore.pem verify optional force-tlsv12 ciphers ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:AES128-SHA:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-GCM-SHA256 npn http/1.1 curves P-256:P-384:P-521 prefer-client-cip
Thanks,
Gayathri
