Today I started with HAProxy on my Pi at home, read my share of the docs and ventured composing a config.
I feel insecure, especially because I want to keep my SSH access. Therefore I would appreciate any help, and pointers to good resources for help.
My situation:
A DSL line with a fixed IPv4 and IPv6, and a router opening certain ports to my Pi
A Pi with Debian Jessie up to date and secured with IPTables
The Pi serves SSH, Apache (80 & 443), home automation 1 (ports x-z) and 2 (port w), Webmin
I have been advised to use HAProxy to ReverseProxy my home automation server.
I want https://mi_ip/bla/bli specifically go to http://localhost:y/blo/blu.
My questions beforehand:
Ports I don’t mention in the HAProxy config, are they untampered passed on? E.g., will I have full SSH access if I don’t mention the SSH port?
Does HAProxy have any other advantages on a single Pi? Can it enhance performance and security?
Is HAProxy acting before or after IPTables?
I made this draft config file:
listen apache
bind *:443
server web localhost
listen home_automation.1
bind http://*:x/bla/bli
server server1 http://localhost:y/blo/blu
listen home_automation.2
bind *:z
server server2 localhost:p
Apologies if I understand something completely wrong, and thanks for any replies!
Haproxy doesn’t do anything unless you configure it to do so. It isn’t a router!
Possibly yes, maybe it does the opposite for you, it all depends on how you configure it.
Haproxy is an application, iptables is part of the kernel. So iptables/routing/masquerading runs first, and haproxy comes after. Haproxy is an application just like Apache, sshd, mysql or minecraft is.
That’s invalid. You cannot specify any URLs here, if your basic configuration contains “http://” you are doing it wrong. You also have to specify the exact port, at the very least when calling bind. It may be omitted on the server line, in that case it will use the original destination port from the frontend/bind section.
Haproxy can forward TCP (at layer 4) or HTTP traffic.
Well, I have been studying both a few hours and was left with the questions I had. For a newbie these doc’s are not that easy to understand.
Great, thanks for these clarifications. So I could safely start with
listen apache
bind *:443
bind *:x
server server1 localhost:y
bind *:z
Then a new question. I just studied the chapter on Using ACLs and fetching samples. Wanting to allow passage only of http://my_url/bli/bla can I add a rule “acl -m dir /bli/bla” to one of the proxies?
