Greetings,
I’m running the latest HAProxy 2.4.2 here with a quite simple configuration for a stats page:
# Stats Page
frontend stats-front
bind *:8080
default_backend stats-back
backend stats-back
acl admin_access src # list of internal ip addresses
stats admin if admin_access
stats auth XXX:XXX
stats refresh 10s
stats show-legends
stats show-node
stats uri /haproxy/stats
We have a monitoring check for Icinga2 written in Python, using the Python Requests library which fails sporadically. Whenever this is the case, the curl command on the command line fails as well with the message curl: (18) transfer closed with outstanding read data remaining, even if the output looks quite complete compared to echo "show stat" | nc -U /run/haproxy/admin.sock.
Now I’m wondering if I’m missing something or if this probably could be a bug?
Thanks in advance for any support & Regards,
Dominic
