I have a simple config with a single ACL and a matching backend. The issue I’m having is that all traffic is showing up under the default backend in the stats page. How do I make the traffic show up under the backend that the acl is pointing to? HA-Proxy version 1.8.8-1 2018/04/19
frontend http-justfoia.com_atlhap1-p-mcci
frontend https-justfoia.com_atlhap1-p-mcci
bind *:443
acl aikensc-justfoia-com hdr_dom(host) aikensc.justfoia.com
use_backend aikensc-justfoia-com if aikensc-justfoia-com
default_backend backend-atlwebx-p-mcci
option httpchk GET /HealthCheck.txt HTTP/1.0\r\nHost:\ aikensc.justfoia.com
http-check expect string I\ am\ Healthy
server https-atlweb1-p-mcci 172.16.64.243:443 check ssl
server https-atlweb2-p-mcci 172.16.64.244:443 check ssl
server http_atlweb1-p-mcci 172.16.64.243 check port 80
server http_atlweb2-p-mcci 172.16.64.244 check port 80
bind *:8000 ssl crt /etc/ssl/private/cert.pem
stats uri /
stats auth user:pass
