Stick Table / Entries addded then removed
stick-table type ip size 1m expire 24h store gpc0,gpc0_rate(30s)
http-request track-sc1 hdr(x-forwarded-for) table Abuse1 if METH_POST
http-request sc-inc-gpc0(1) if METH_POST req_rate_api_abuse_1 is_custom_url !is-whitelisted-ip
Does HA Proxy remove entries from the table if the method would be different ?
ie: doing a POST and then doing a GET ?
Also another quesion…
When doing hot reloading it seems to clean the sticky table how can I preserve it between reloads?
Oh i guess…
Configure the peer section with the local peer name, this way the new process will connect to the old process on reload and transfer the contents of the stick table:
https://cbonte.github.io/haproxy-dconv/1.8/configuration.html#3.5-peer
