Stop logging to journalctl
Hello, I’m on v1.8, I want to stop logging the details to journalctl, but keep /var/log/haproxy.log
log /dev/log local2
timeout queue 1m
timeout client 10s
timeout server 10s
timeout http-keep-alive 10s
timeout check 5s
bind 10.15.15.123:8404
stats uri /stats
stats refresh 5s
stats auth wsadmin:101Ram
stats admin if LOCALHOST
option dontlog-normal
frontend devldap
bind 10.15.15.22:395
default_backend devldap_backend
option log-health-checks
    server devldap_390_1 ldapd1.com:395 check observe layer4 error-limit 10 on-error mark-down
    server devldap_390_2 ldapd2.com:395 check observe layer4 error-limit 10 on-error mark-down
Set the log to other path different than /dev/log like for example /dev/halog and use rsyslog, for example, to listen there and write the content to /var/log/haproxy.log
we used to do this with rsyslog.
In haproxy.conf, configure the path where the logs are sent. In global section we have (be careful as it may be a chrooted path):
    log         /log  local2
    chroot      /var/lib/haproxy
After we use rsyslog. You have to create the log file as socket file, then configure rsyslog as usual to send the logs where you want :
# Create an additional socket in haproxy's chroot in order to allow logging via
# /dev/log to chroot'ed HAProxy processes
$AddUnixListenSocket /var/lib/haproxy/log
$template message_only,"%msg%\n"
# Send HAProxy messages to a dedicated logfile
if $programname startswith 'haproxy' then /var/log/haproxy.log;message_only
#& -?haproxy_by_minute;message_only
& stop
Restart rsyslog then restart haproxy and you should be able to get your logs in the right file
