Dear all:
I’m using the fuction ddr_dom(host) to filter some links:
The initial acl rule is as follows:
acl is_newsohu path_beg /vrs_flash hdr_dom(host) -i hot.vrs.sohu.com
use_backend proxy-sohuPhone if is_newsohu
It is not working correctly for the link (see next reply) which should pass the rule, instead of blocked by the rule.
Then I updated the acl rule to this:
acl is_newsohu path_beg /vrs_flash hdr_dom(host) -i hot.vrs.sohu.com:80
It is still not working either.
Can you guys help me check how to fix this issue?
