Anyone able to tell me what I’m doing wrong here? Most of my services are run on sub domains and work perfectly, However, for SSO to work I need Plex to be a sub directory. My dashboard service (Organizr) is at mydomain.com, and for plex I have told it to point to mydomain.com/plex. So, the relevant part of my config currently looks something like this:
frontend shared-frontend-merged
acl ACL1 var(txn.txnhost) -m str -i mydomain.co.uk
acl ACLPlex var(txn.txnpath) -m beg -i /plex
use_backend Organizr_ipvANY if ACL1
use_backend Plex_ipvANY if ACLPlex
Yet when I try to access Plex through Organizr I’m faced with a 404 served up by nginx. Have I missed something obvious?
The first backend wins because the ACL1 matches both in both conditions.
Einter switch the use_backend order, or (to be clear) add an if ACL1 !ACPlex for the first one, and ACL1 ACLPlex for the second one.
(Else only by using ACLPlex one could use any domain that points to that IP to access your service.)
Hmm, that makes sense and it has definitely done something. However, both methods are now returning a 401 unauthorized. Does this provide any clue as to where to go from here? Apologies, I’m rather new to HAproxy. I probably should have done this with nginx but I’m so far down the rabbit hole I’d like to get it finished!
Unless you’ve explicitly configured authentication in HAProxy, then the status code 401 most likely is replied by the backend servers (i.e. NGinx or something downstream).
Perhaps paste the entire HAProxy configuration?
Thanks for this, I’m sure you’re going to tell me I’ve done something really strange lol.
# Generated on: 2019-07-03 16:44
maxconn 1000
log /var/run/log syslog debug
stats socket /tmp/haproxy.socket level admin
uid 80
gid 80
nbproc 1
hard-stop-after 15m
chroot /tmp/haproxy_chroot
log-send-hostname HaproxyMasterNode
listen HAProxyLocalStats
stats admin if TRUE
stats show-legends
timeout client 5000
timeout server 5000
frontend http-to-https
bind 62.20.15.210:80 name 62.20.15.210:80
timeout client 30000
acl mydomain.co.uk-Redirect var(txn.txnhost) -m beg -i mydomain.co.uk
http-request redirect scheme https
bind 62.20.15.210:443 name 62.20.15.210:443 no-sslv3 force-tlsv12 ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256 ssl crt-list /var/etc/haproxy/shared-frontend.crt_list
acl https ssl_fc
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^mydomain\.co\.uk(:([0-9]){1,5})?$
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^fileshare\.mydomain\.co\.uk(:([0-9]){1,5})?$
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^grafana\.mydomain\.co\.uk(:([0-9]){1,5})?$
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^matrix\.mydomain\.co\.uk(:([0-9]){1,5})?$
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^nextcloud\.mydomain\.co\.uk(:([0-9]){1,5})?$
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^ombi\.mydomain\.co\.uk(:([0-9]){1,5})?$
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^pfsense\.mydomain\.co\.uk(:([0-9]){1,5})?$
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^portainer1\.mydomain\.co\.uk(:([0-9]){1,5})?$
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^portainer2\.mydomain\.co\.uk(:([0-9]){1,5})?$
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^proxmox\.mydomain\.co\.uk(:([0-9]){1,5})?$
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^radarr\.mydomain\.co\.uk(:([0-9]){1,5})?$
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^riot\.mydomain\.co\.uk(:([0-9]){1,5})?$
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^sonarr\.mydomain\.co\.uk(:([0-9]){1,5})?$
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^ssh\.mydomain\.co\.uk(:([0-9]){1,5})?$
acl aclcrt_shared-frontend var(txn.txnhost) -m reg -i ^wiki\.mydomain\.co\.uk(:([0-9]){1,5})?$
acl ACL2 var(txn.txnhost) -m str -i riot.mydomain.co.uk
acl ACL3 var(txn.txnhost) -m str -i matrix.mydomain.co.uk
acl ACL4 var(txn.txnhost) -m str -i sonarr.mydomain.co.uk
acl ACL5 var(txn.txnhost) -m str -i radarr.mydomain.co.uk
acl ACL6 var(txn.txnhost) -m str -i nextcloud.mydomain.co.uk
acl ACL7 var(txn.txnhost) -m str -i ombi.mydomain.co.uk
acl ACL12 req.cook_cnt(organizr_token_b112kkk-hjib-7891-9ed6-e8eb190763f2) gt 0
acl ACL8 var(txn.txnhost) -m str -i fileshare.mydomain.co.uk
acl ACL9 var(txn.txnhost) -m str -i grafana.mydomain.co.uk
acl ACL11 var(txn.txnhost) -m str -i pfsense.mydomain.co.uk
acl ACL13 var(txn.txnhost) -m str -i proxmox.mydomain.co.uk
acl ACL18 var(txn.txnhost) -m str -i portainer1.mydomain.co.uk
acl ACL14 var(txn.txnhost) -m str -i portainer2.mydomain.co.uk
acl ACL16 var(txn.txnhost) -m str -i ssh.mydomain.co.uk
http-request set-var(txn.txnpath) path
use_backend Organizr_ipvANY if ACL1 !ACLPlex
use_backend Plex_ipvANY if ACL1 ACLPlex
use_backend Riot_ipvANY if ACL2
use_backend Matrix_ipvANY if ACL3
use_backend Sonarr_ipvANY if ACL4 ACL12
use_backend Radarr_ipvANY if ACL5 ACL12
use_backend Nextcloud_ipvANY if ACL6 ACL12
use_backend Ombi_ipvANY if ACL7 ACL12
use_backend Fileshare_ipvANY if ACL12 ACL8
use_backend Grafana_ipvANY if ACL9 ACL12
use_backend PFsense_ipvANY if ACL11 ACL12
use_backend Proxmox_ipvANY if ACL13 ACL12
use_backend Portainer_ipvANY if ACL18 ACL12
use_backend Portainer2_ipvANY if ACL14 ACL12
use_backend SSH_ipvANY if ACL16 ACL12
id 100
timeout connect 30000
timeout server 30000
server Organizr 192.168.2.10:8899 id 101 check inter 1000
backend Plex_ipvANY
id 110
server Plex 192.168.1.12:32400 id 101 check inter 1000
backend Riot_ipvANY
id 102
server Riot 192.168.2.10:443 id 101 ssl check inter 1000 verify none
id 103
server Matrix 192.168.2.10:443 id 101 ssl check inter 1000 verify none
id 104
server Sonarr 192.168.1.14:8989 id 101 check inter 1000
id 105
server Sonarr 192.168.1.14:7878 id 101 check inter 1000
id 106
server Nextcloud 192.168.2.10:8080 id 101 check inter 1000
backend Ombi_ipvANY
id 107
server Ombi 192.168.1.14:3579 id 101 check inter 1000
id 108
server Fileshare 192.168.2.10:8000 id 111 check inter 1000
id 109
server Grafana 192.168.2.10:3000 id 101 check inter 1000
id 112
server PFsense 192.168.1.1:81 id 101 ssl check inter 1000 verify none
id 113
server Proxmox 192.168.1.2:8006 id 101 ssl check inter 1000 verify none
id 114
server Portainer 192.168.1.14:9000 id 115 check inter 1000
id 117
server Portainer2 192.168.2.10:9000 id 115 check inter 1000
backend SSH_ipvANY
id 116
server SSH 192.168.2.10:5800 id 111 check inter 1000
Yup… Very strange…
But before that, quickly looking through your configuration I wouldn’t say that the 401 is from HAProxy, but in fact from one of the backend servers… (I would certainly search there…)
Check the log to see if a server was actually selected.
Now for the “very strange part”:
- you could give some relevant names to the ACL’s, as it’s almost impossible to trace them…
- the
aclcrt_shared-frontend isn’t used anywhere; moreover it would be useless, as any behaving HTTP(S) client (given that HAProxy listens on only 443), wouldn’t send such a Host header…
- you use
var(txt...) when you don’t need to (because you are using request headers only in the request processing, thus they are available;) (you could use them if you needed these values in response processing;)
- do not use
-m beg with domain names; (as for example whatever.mydomain.co.uk won’t be matched;) (use instead -m dom if I remember correctly;)
- I don’t think SSH would work this way (unless you have something that proxies between HTTP and SSH);
Well, looks like I have some homework to do! With ACLnames you’re absolutely right and it soon spiralled, changing them is on the list! The rest appears appears to be a combination of tutorials I followed and the options availale in the PFsense package (eg. “host matches”). As for the SSH, I installed an SSH client in docker that serves a web interface, so I can use that to SSH on my lan (as the container makes the requests). I’ll go and do some research in that case, disappointing that it wasn’t a quick fix! Thanks for your time though, appreciated.
I know this is an older thread but were you ever able to get your setup working? Mind sharing the solution
I’m new to HAProxy and running into issues. Trying to set up a bunch of subdirectories for ‘/sonarr’, ‘/radarr’, ‘/plex’, etc.
