I’m using http and tcp mode in single haproxy. For HTTP I’m routing based on acl with domain names according to the matched subpaths it’ll route the traffic to backend, I tried with seperate frontend for mode http and tcp, the tcp connections were getting as http inside haproxy. When I tried to provide only tcp mode it was working but when I tend to use both tcp and http, all requests were made as http requests. I tried using docker compose deployment for tcp, but that ends in vain. Please help me resolve this issue. attached the file contents:
My Haproxy version is 2.8
Try using
mode http for bind 443 and bind 80 and mode tcp for bind :5671 in the single frontend like this
bind :80
bind :443 ssl crt /etc/haproxy/certs/example.com.pem crt /etc/haproxy/certs/dev.example.com.pem crt /etc/haproxy/certs/hrms.example.com.pem
bind :5671 ssl crt /etc/haproxy/certs/dev.example.com.pem
I need to make rabbitmq connection on port 5671 with TLS, that is the goal
Please do not tag me. This is a community, not a private support channel.
If you have a urgent issue in commercial application, reach out to haproxy.com for commercial support.
Sorry for tagging you, I saw for most you’ve reached out and helped that’s why I tagged you!
Been struck on this for almost a week and tried documentation steps and blogs, didn’t got fix.
Any leads on this will greatly help!
