I have three clustered servers with two network connections; one network card runs HTTPS, and the database data flows through the second network card. The network is isolated, with no internet connection and no data exchange between the two networks. The HAProxy server has the second network card, so it can communicate with the network carrying the database data.
This is a section of the configuration.
listen Apps
bind *:443
maxconn 2400
fullconn 2400
option httpchk HEAD /
compression algo gzip
compression type text/css text/html text/javascript application/javascript text/plain text/xml application/json
option tcp-check
What should I write there?
server BackEnd-01 192.168.0.1:8156 check maxconn 800 weight 1 fall 1 rise 3
server BackEnd-02 192.168.0.2:8156 check maxconn 800 weight 1 fall 1 rise 3
server BackEnd-03 192.168.0.3:8156 check maxconn 800 weight 1 fall 1 rise 3
The network of the second network card is 192.168.254.0/24
Thank you
