To accelerate L4 performance between origin and end-user, I’ve utilized TCP fast open feature on HAProxy.
My expectation is that all requests are accelerated by TCP fast open. But on the result, all is not always accelerated like image.
I want to know how TCP fast open is always applied to all requests.
Are there any other configuration for doing it ?
My test environment is as follow. And I’ve configured TCP fast open at Edge and Relay.
Client(Google VM on Singapore) -> Edge (AWS VM on Singapore) -> Parent (AWS VM on KR) -> Origin(AWS VM on KR)
Test program was run periodically on the client. ex) curl http://www.foo.com:90/10K.bin
Linux version and TCP fast open of Edge & Parent server.
# uname -a
Linux edge_sg_01 4.14.177-139.254.amzn2.x86_64 #1 SMP Thu May 7 18:48:23 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux
# cat /proc/sys/net/ipv4/tcp_fastopen
3
Haproxy -vv
HA-Proxy version 2.1.7 2020/06/09 - https://haproxy.org/
Status: stable branch - will stop receiving fixes around Q1 2021.
Known bugs: http://www.haproxy.org/bugs/bugs-2.1.7.html
Running on: Linux 4.14.177-139.254.amzn2.x86_64 #1 SMP Thu May 7 18:48:23 UTC 2020 x86_64
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wno-implicit-fallthrough -Wno-stringop-overflow -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
OPTIONS = USE_PCRE=1 USE_THREAD=1 USE_LIBCRYPT=1 USE_OPENSSL=1 USE_ZLIB=1 USE_TFO=1 USE_NS=1 USE_SYSTEMD=1
Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER +PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL +BACKTRACE +GETADDRINFO +OPENSSL -LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
(protocols marked as cannot be specified using 'proto' keyword)
: mode=HTTP side=FE|BE mux=H1
Available services : none
[FCGI] fcgi-app
Configuration on Parent
frontend tcp_90
bind *:90 tfo
default_backend web_svr_90
backend tcp_svr_90
server kr_origin_90 xxx.xxx.xxx.xxx:90
Configuration on Edge
frontend tcp_90
bind *:90
default_backend tcp_svr_90
backend tcp_svr_90
retry-on conn-failure empty-response response-timeout
server kr_parent_tcp_00 xxx.xxx.xxx.xxx:90 tfo
