over at the OPNsense forum I created a widely used tutorial for configuring HAProxy with Let’s Encrypt on OPNsense. To me this setup can always be improved. This is way I am coming here for advise.
Current setup
Only TCP port 80 and 443 are exposed to the WAN.
The SNI_frontend defaults to redirecting traffic using an address on the localhost to the HTTP_frontend and HTTPS_frontend.
This is so I can also have TCP based services like OpenVPN exposed using port 443.
All of the above is currently working just fine.
The HTTPS_frontend is currently defaulting to the SUSPICIOUS_SNI_backend with only a http-request silent-drop rule on it, that will take action if no matching SNI record can be found in a mapfile or rule.
While this is also working fine it still presents the user with “Error: Secure connection failed”.
Setting this http-request silent-drop directly on the SNI_frontend works as intended and the connection times out.
What is the goal?
In short I would like to perform the SNI check directly on the SNI_frontend.
- HAProxy should verifiy the FQDN that is beeing accessed against a mapfile.
- The mapfile contains only the valid FQDNs redirecting them all to the SSL_backend.
- If no matching FQDN can be found the
http-request silent-dropshould take action.
Attempted config
The below config is working fine for HTTP traffic.
Valid FQDNs accessing the SNI_frontend using HTTP get redirected to the HTTP_frontend via the SSL_backend and from there redirected to HTTPS_frontend.
Invalid/Unknown FQDNs receive the http-request silent-drop.
However the below config is not working at all for HTTPS traffic. No matter if the FQDN is valid or not.
HTTPS traffic is always presented with “Error: Secure connection failed”.
The log indicates that the traffic gets stuck at the SNI_frontend.
The HTTPS_frontend gets no hits whatsoever.
logfile
2023-12-05T13:43:45 Informational haproxy Connect from CLIENT_PUBLIC_IP:38137 to HAPROXY_PUBLIC_IP:443 (0_SNI_frontend/TCP)
2023-12-05T13:43:42 Informational haproxy Connect from CLIENT_PUBLIC_IP:61996 to HAPROXY_PUBLIC_IP:80 (1_HTTP_frontend/HTTP)
2023-12-05T13:43:42 Informational haproxy Connect from CLIENT_PUBLIC_IP:61996 to HAPROXY_PUBLIC_IP:80 (0_SNI_frontend/TCP)
relevant config export
# Frontend: 0_SNI_frontend (Listening on 0.0.0.0:80, 0.0.0.0:443)
frontend 0_SNI_frontend
bind 0.0.0.0:80 name 0.0.0.0:80
bind 0.0.0.0:443 name 0.0.0.0:443
default_backend SUSPICIOUS_SNI_backend
# logging options
# ACL: VALID_SNI_HTTP_condition
acl acl_656a32a6dc8cf7.04655470 req.proto_http
# ACL: VALID_SNI_SSL_condition
acl acl_656a3297938019.26511022 req.ssl_hello_type 1
# ACTION: TCP_RequestInspectDelay_rule
# NOTE: actions with no ACLs/conditions will always match
# ACTION: VALID_SNI_REDIRECT_rule
use_backend %[req.hdr(host),lower,map_dom(/tmp/haproxy/mapfiles/6569ef70ad5e48.90806906.txt)]
# ACTION: VALID_SNI_HTTP_rule
tcp-request content accept if acl_656a32a6dc8cf7.04655470
# ACTION: VALID_SNI_SSL_rule
tcp-request content accept if acl_656a3297938019.26511022
VALID_SNI_mapfile
# domain.com
cloud.domain.com SSL_backend
subdomain.domain.com SSL_backend
I hope someone can point me in the right direction.
Thank you very much!
TheHellSite
