TLS 1.0 enabling
Good morning,
Has functionality changed from 1.9 to 2.0, in terms of TLS 1.0? Does it need to be explicitly added in the config now? If I switch to 2.0 on my exchange load balancer, our W7 Outlook 2016 clients stop as it relies on TLS 1.0.
James
No, it has not changed.
I suggest you provide the configuration, logs and the output of haproxy -vv from both 1.9 and 2.0.
1.9:
HA-Proxy version 1.9.7 2019/04/25 - https://haproxy.org/
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
OPTIONS = USE_LIBCRYPT=1 USE_CRYPT_H=1 USE_ZLIB=1 USE_OPENSSL=1 USE_SYSTEMD=1 USE_PCRE=1
h2 : mode=HTX side=FE|BE
h2 : mode=HTTP side=FE
: mode=TCP|HTTP side=FE|BE
2.0:
HA-Proxy version 2.0.3 2019/07/23 - https://haproxy.org/
TARGET = linux-glibc
CC = gcc
OPTIONS = USE_PCRE=1 USE_LIBCRYPT=1 USE_CRYPT_H=1 USE_OPENSSL=1 USE_ZLIB=1 USE_SYSTEMD=1
Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER +PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL +GETADDRINFO +OPENSSL -LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
h2 : mode=HTTP side=FE mux=H2
: mode=HTX side=FE|BE mux=H1
: mode=TCP|HTTP side=FE|BE mux=PASS
Available services : none
I am using the same config for both:
option dontlognull # Do not log connections with no requests
option redispatch # Try another server in case of connection failure
option contstats # Enable continuous traffic statistics updates
retries 3 # Try to connect up to 3 times in case of failure
timeout connect 5s # 5 seconds max to connect or to stay in queue
timeout http-keep-alive 1s # 1 second max for the client to post next request
timeout http-request 15s # 15 seconds max for the client to send a request
timeout queue 30s # 30 seconds max queued on load balancer
timeout tarpit 1m # tarpit hold tim
backlog 10000 # Size of SYN backlog queue
balance roundrobin #alctl: load balancing algorithm
mode tcp #alctl: protocol analyser
option tcplog #alctl: log format
log global #alctl: log activation
timeout client 1000s #alctl: client inactivity timeout
timeout server 1000s #alctl: server inactivity timeout
default-server inter 3s rise 2 fall 3 #alctl: default check parameters
bind :9000
stats hide-version
stats uri /
stats refresh 30s
stats show-node
frontend ft_443exchange_tcp
bind 192.168.100.47:443 name https #alctl: listener https configuration.
maxconn 10000 #alctl: connection max (depends on capacity)
default_backend bk_443exchange_tcp #alctl: default farm to use
server EX02 192.168.100.28:443 maxconn 10000 check
server EX03 192.168.100.15:443 maxconn 10000 check
frontend ft_80exchange_tcp
bind 192.168.100.47:80 name https #alctl: listener https configuration.
default_backend bk_80exchange_tcp #alctl: default farm to use
server EX02 192.168.100.28:80 maxconn 10000 check
server EX03 192.168.100.15:80 maxconn 10000 check
frontend ft_25exchange_tcp
bind 192.168.100.47:25 name smtp #alctl: listener https configuration.
acl network_allowed src 192.168.100.0/24 192.168.200.0/24 192.168.3.0/24 192.168.2.0/24 207.46.100.0/24 134.170.132.0/24 52.100.0.0/14 40.107.128.0/18 40.107.0.0/17 23.103.212.0/22 23.10$
tcp-request connection reject if !network_allowed
use_backend bk_25exchange_tcp
server EX02 192.168.100.28:25 maxconn 10000 check
server EX03 192.168.100.15:25 maxconn 10000 check
How do you come to the conclusion that this is about TLSv1.0?
Are you aware of TLS handshake failures with those clients?
Again, please do share the logs.
Hi Lukas,
My conclusion is not scientific or log based at all, just from knowing how my system works. When we are running 1.9, W7 and W10 Outlook 2016 clients work, when we switch over to 2.0, all the W7 clients stop but the W10 keep going. The only difference I can find is that older W7 clients connect to Exchange via TLS1.0 and newer clients use a newer version.
I will do some more testing and update, if nothing has changed and TLS1.0 should be allowed as default as before, then I need to do more of a deep dive into it with some wiresharking.
There is also a Windows 7 hotfix/update that forces higher TLS, so I may push this out to some clients and see if a switch to 2.0 affects them afterwards.
Thanks for the help so far, great product.
James
