Troubleshooting 503 when proxying Proxmox management interface
Hi all, thanks in advance for any help you might have to offer.
I’m currently running into a rather strange issue that has had me totally stumped for the last several hours. I’m simply trying to proxy my Proxmox management interface behind HAProxy so that I have full SSL/stricter firewall rules/etc, but I’m met with constant 503s when I try to access the endpoint. Note that this is all in my LAN, not exposed to the internet, obviously.
My configuration is as follows: My firewall is OPNsense, and I’m using the HAProxy plugin. Proxmox is running in my management VLAN. I can access the interface by its hostname or IP address on port 8006 as expected. I’m proxying through my administration HAProxy frontend, as I do with all my other management interfaces like switches, aps, etc., which are all working fine.
I’m not a HAProxy wizard, but I have configured it multiple times on several systems so I definitely have an okayish working knowledge of it. I’ve ensured that my DNS override is pointing to the correct HAProxy frontend, quadruple checked my rules/conditions, ensured SSL is enabled (but not checked) on the server, ensured the port is correct (8006), disabled health checking, set the server as the default backend pool for the frontend, and pretty much everything else I can think of. Nothing is getting rid of the 503 error.
This is all very strange since I have identical configuration for all my other management interfaces, and they all work fine, but for whatever reason, Proxmox is being extremely difficult. This is also my first time using OPNsense (I’m usually a pfSense guy), and I’m having a bit of trouble getting HAProxy to give me any useful logs, which has compounded my troubleshooting.
I’m open to pretty much any suggestion here, and once again, thanks for any input. Finally, here’s my full HAProxy config:
    uid                         80
    gid                         80
    chroot                      /var/haproxy
    stats                       socket /var/run/haproxy.socket group proxy mode 775 level admin
    nbthread                    4
    hard-stop-after             60s
    no strict-limits
    maxconn                     10000
    limited-quic
    httpclient.resolvers.prefer   ipv4
    tune.ssl.default-dh-param   4096
    spread-checks               2
    tune.bufsize                16384
    tune.lua.bool-sample-conversion normal
    tune.lua.maxmem             0
    log                         /var/run/log local0 info
    lua-prepend-path            /tmp/haproxy/lua/?.lua
    log     global
    option redispatch -1
    maxconn 5000
    timeout client 30s
    timeout connect 30s
    timeout server 30s
    default-server init-addr last,libc
    default-server maxconn 5000
# Public Service: Admin_HTTP_Frontend (Listening on 10.0.20.1:80)
frontend Admin_HTTP_Frontend
    bind 10.0.20.1:80 name 10.0.20.1:80
    # logging options
    # CONDITION: NoSSL_condition
    acl acl_699b637a917578.96201502 ssl_fc
    # RULE: HTTP_to_HTTPS_rule
    http-request redirect scheme https code 301 if !acl_699b637a917578.96201502
# Public Service: Admin_HTTPS_frontend (Listening on 10.0.20.1:443)
frontend Admin_HTTPS_frontend
    http-response set-header Strict-Transport-Security "max-age=15768000"
    bind 10.0.20.1:443 name 10.0.20.1:443 ssl curves secp384r1  prefer-client-ciphers ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256 ciphersuites TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256 alpn h2,http/1.1 crt-list /tmp/haproxy/ssl/699fb4394f9419.96453892.certlist
    # logging options
    # CONDITION: FW1_condition
    acl acl_699b6a37ebfe34.02894762 hdr(Host) -i fw1.home.example.com
    # CONDITION: Switch1_condition
    acl acl_699ba8ed12c446.65075432 hdr(Host) -i switch1.home.example.com
    # CONDITION: AP1_condition
    acl acl_699e43e198e1b0.61616432 hdr(Host) -i ap1.home.example.com
    # CONDITION: NAS1_condition
    acl acl_699e48645400c6.77972048 hdr(Host) -i nas1.home.example.com
    # CONDITION: Hyper1_condition
    acl acl_69a8cbba143792.24371812 hdr(Host) -i hyper1.home.example.com
    # RULE: OPNsense_rule
    use_backend FW1 if acl_699b6a37ebfe34.02894762
    # RULE: Switch1_rule
    use_backend Switch1 if acl_699ba8ed12c446.65075432
    # RULE: AP1_rule
    use_backend AP1 if acl_699e43e198e1b0.61616432
    # RULE: NAS1_rule
    use_backend NAS1 if acl_699e48645400c6.77972048
    # RULE: Hyper1_rule
    use_backend Hyper1_pool if acl_69a8cbba143792.24371812
# Backend Pool: SSL_Backend ()
backend SSL_Backend
    # health checking is DISABLED
    balance source
    # stickiness
    stick-table type ipv4 size 50k expire 30m
    stick on src
    server SSL_Server localhost send-proxy-v2 check-send-proxy
# Backend Pool: FW1 ()
backend FW1_pool
    balance source
    # stickiness
    stick on src
    http-reuse safe
    server FW1 opnsense.home.example.com:10433 ssl alpn h2,http/1.1 verify none
# Backend Pool: Switch1 (TP-Link SG2210P)
backend Switch1_pool
    balance source
    # stickiness
    stick on src
    http-reuse safe
    server Switch1 TL-SG2210P.home.example.com:443 ssl alpn h2,http/1.1 verify none
# Backend Pool: AP1 (TP-Link EAP610)
backend AP1_pool
    balance source
    # stickiness
    stick on src
    http-reuse safe
    server AP1 EAP610.home.example.com:443 ssl alpn h2,http/1.1 verify none
# Backend Pool: NAS1 (TrueNAS Server)
backend NAS1_pool
    balance source
    # stickiness
    stick on src
    http-reuse safe
    server NAS1 truenas.home.example.com:443 ssl alpn h2,http/1.1 verify none
# Backend Pool: Hyper1_pool (Proxmox M70q)
backend Hyper1_pool
    balance source
    # stickiness
    stick on src
    http-reuse safe
    server Hyper1 proxmox.home.example.com:8006 ssl alpn h2,http/1.1 verify none
# statistics are DISABLED
I figured out the (extremely irritating) solution thanks to this thread on Stackoverflow. I somehow had ended up with two HAProxy instances running at once, so any requests I submitted to my Proxmox endpoint were hitting the instance that hadn’t been updated with my new config. Killed both instances, started it again, and instantly had the expected behavior!
