I have found this " [tune.h2.initial-window-size] " command for faster uploads/connections… Can we use the same command in TCP mode… Will it work? or is there any option to increase the tcp window size ? Please help…
is about the HTTP/2 window size. This has nothing to do with the window size of the TCP connection, therefor it is applicable only to H2.
