Hello
I can start haproxy in foreground mode by following command:
haproxy -f /etc/haproxy/haproxy.cfg
and able to connect.
But when I try to start it in background mode using:
systemctl start haproxy.service
It doesn’t throw any error but I observed connectivity failure and when I check the service status using command service haproxy status found service is not active. I also tried command service haproxy restart but no success. How can I start HAProxy service in background mode? I have attached the haproxy.cfg(sample file) .
You should add the keyword daemon in your global section.
https://cbonte.github.io/haproxy-dconv/2.0/configuration.html#daemon
