Hi there,
Compiling haproxy 2.2 w/ TRACE=1 on mac host, inside ubuntu container, using this command,
make -j $(nproc) TARGET=linux-glibc USE_LUA=1 TRACE=1
throws following error:
/usr/bin/ld: src/calltrace.o: in function `make_line':
/opt/src/calltrace.c:204: undefined reference to `rdtsc'
/usr/bin/ld: src/calltrace.o: in function `calltrace':
/opt/src/calltrace.c:277: undefined reference to `rdtsc'
collect2: error: ld returned 1 exit status
make: *** [Makefile:864: haproxy] Error 1
Following fixes the issue (found on SO):
__inline__ uint64_t rdtsc(void)
uint32_t lo, hi;
__asm__ __volatile__ (
"xorl %%eax,%%eax \n cpuid"
::: "%rax", "%rbx", "%rcx", "%rdx");
__asm__ __volatile__ ("rdtsc" : "=a" (lo), "=d" (hi));
return (uint64_t)hi << 32 | lo;
I don’t understand why it doesn’t work out of the box…surely the patch should not needed. Am I missing something?
Thanks,
Karan
