Unreachables backends from my HAProxy
Hello all, i’m trying to explain my setup at my best. Just for testing purposes i’m trying to expose a jenkins instance and a web-server behind an HAproxy. The environment is running locally on my machine using vagrant for provisioning.
Machine A: 192.168.121.10
Machine B: 192.168.121.11
On machine A, webserver is apache and it runs on default settings on port 80 and there is a simple index page that i want to reach. On the same machine a docker image of Jenkins is up and running on port 9000.
On machine B i configured my HAProxy as:
  log 127.0.0.1 local0 notice
  maxconn 4096
  maxconn 20
  timeout client 60s
  timeout server 60s
frontend main
  bind 192.168.121.11:9000
  acl url_apache path_beg /apache
  use_backend apache if url_apache
  default_backend  jenkins-mstr
  server jenkins01 192.168.121.10:8000 check
backend apache
  reqrep ^([^\ ]*)\ /apache(.*)  \1\ \2 #convert /apache from frontend to / on backend
  server apache01 192.168.121.10:80 check
As you see what i want to achieve is to reach the apache-server from machineB:9000/apache and reach jenkins from machineB:9000 .
Instead, what i got is:
 machineB:9000 --> 503
 machineB:9000/apache --> 400 bad request
I do not have any additional conf files for apache and i restart my HAProxy with systemctl restart haproxy to let configs take effetcs.
What am i missing ? I’m really stuck and any help would be extremely great.
Are you sure you exposed your jenkins docker container on this port?
Yes sure, i can reach Jenkins from machineA with no problem at all
