Use different TLS versions
Hi!
I have the HAProxy working well but now, we noticed that an old app on one of the containers needs TLS 1.1 and I’m requiring 1.2 and minimum and I don’t want to degrade all the other apps to support the legacy.
Since I’m using TLS termination and I can’t bind 443 again, how can I support a different TLS version to a specific backend?
Thanks a lot!
When using OpenSSL 1.1.1, you can use the crt-list feature to configure TLS settings per certificate.
Thanks @lukastribus for your help.
I added the crt-list.txt on the config file and, following the example on the docs, added a filter on the desired line:
/etc/ssl/haproxy/xpto.com.pem [ssl-min-ver TLSv1.1] xpto.com
It doesn’t seem to make a difference on this one, and it seems to mess up the following lines. Am I typing it incorrectly?
Thanks again!
Can you share the output of haproxy -vv? How does the certificate structure look like?
Not sure what that means? Mess up how?
with mess up I mean that it mixes certificates between different domains and a “Your connection is not secure” appears.
Here’s the -vv output:
ubuntu@haproxy:~$ haproxy -vv
HA-Proxy version 1.8.8-1ubuntu0.10 2020/04/03
TARGET = linux2628
CC = gcc
CFLAGS = -g -O2 -fdebug-prefix-map=/build/haproxy-RAYurj/haproxy-1.8.8=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2
OPTIONS = USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE=1 USE_PCRE_JIT=1 USE_NS=1
Do I need to upgrade to haproxy 2+ to use crt-list?
No, this should be supported in haproxy-1.8 just fine.
Very strange that you get the wrong certificates served now. Can you share your haproxy configuration and give me a better picture about the certificates you are using, and which certificate is shown?
Is the wrong certificate the same one that is shown when you access the IP address of the haproxy in https?
Here’s the haproxy.conf (I only left one and renamed xpto since this a public thread):
timeout client 600s
timeout server 600s
frontend www_frontend
bind *:443 ssl crt-list /etc/haproxy/crt-list.txt
    acl host_xpto hdr(host) -i xpto.com
    use_backend xpto_servers if host_xpto
http-request set-header X-Client-IP %[src]
server xpto xpto.lxd:80
Regarding the wrong certificate, yes, it is.
It uses the first on the crt-list.txt.
You don’t have to specify the snifilter, it’s optional and not needed in this case. I suggest you just try:
in the crt-list.
@lukastribus, you’re awesome.
Apparently the problem was related with the snifilter
Thanks you again for your help!
