V1.6.10 - Soft reload not working under Centos 7.2
Hi - I have two haproxy servers with identical haproxy.cfg files, one running under Ubuntu 16.04, the other Centos 7.2. I need the option to maintain existing connections while loading a new config file, so choose to use the soft reload option. On the Ubuntu server, I can run /etc/init.d/haproxy reload to ‘soft restart’ and it works perfectly, but on the Centos server, the same command doesn’t work.
Haproxy version is this on both:
HA-Proxy version 1.6.10 2016/11/20
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement
OPTIONS =
Built without compression support (neither USE_ZLIB nor USE_SLZ are set)
Compression algorithms supported : identity(“identity”)
Built without OpenSSL support (USE_OPENSSL not set)
Built without PCRE support (using libc’s regex instead)
Built without Lua support
Error on trying a reload is this:
Feb 7 07:26:31 apl00086i3 haproxy[8092]: Proxy http_frontend started.
Feb 7 07:26:31 apl00086i3 haproxy[8092]: Proxy sspe started.
Feb 7 07:26:31 apl00086i3 haproxy[8092]: Proxy stats started.
Feb 7 07:26:31 apl00086i3 systemd: Reloaded SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments…
Feb 7 07:26:31 apl00086i3 systemd: haproxy.service: main process exited, code=killed, status=9/KILL
Feb 7 07:26:31 apl00086i3 haproxy: Shutting down haproxy: [FAILED]
Feb 7 07:26:31 apl00086i3 systemd: Unit haproxy.service entered failed state.
Feb 7 07:26:31 apl00086i3 systemd: haproxy.service failed.
… but if I issue /etc/init.d/haproxy start, it starts correctly, even though the previous command had a ‘FAILED’ state for shutdown:
Feb 7 07:26:41 apl00086i3 systemd: Starting SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments…
Feb 7 07:26:41 apl00086i3 haproxy[8122]: Proxy http_frontend started.
Feb 7 07:26:41 apl00086i3 haproxy[8122]: Proxy sspe started.
Feb 7 07:26:41 apl00086i3 haproxy[8122]: Proxy stats started.
Feb 7 07:26:41 apl00086i3 haproxy: Starting haproxy: [ OK ]
Feb 7 07:26:41 apl00086i3 systemd: Started SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments…
Any clues, please, or suggestions how this can be debugged further, since those log entries aren’t particularly useful?
thanks …
Okay I’m guessing here a little…
However you start it correctly with /etc/init.d/haproxy which would appear to be an old style init script, while the failed reload appears to be using “haproxy.service” suggesting a systemd style script.
Can I check do you have two scripts or is it just me misunderstanding? Normally the systemd script would live here if activated : /etc/systemd/system/multi-user.target.wants/haproxy.service
Also for CentOS 7 and systemd try checking the output of “journalctl -xn” as it may offer more info.
Thanks for your input Aaron. There is no script at /etc/systemd/system/multi-user.target.wants/haproxy.service , only the /etc/init.d/haproxy one.
Reading through the journal log, I think the haproxy.service error was a red herrring, actually … when /etc/init.d/haproxy reload didn’t work, I tried the alternate systemctl reload haproxy command (given that it’s a systemd server), and that’s what threw the ‘Unit haproxy.service entered failed state’ error.
The order of commands I actually tried were:
… this came back with an error telling me to do a systemctl daemon-reload, which I did:
journalctl -u haproxy.service shows this error resulting from these two commands:
Feb 07 07:22:21 apl00086i3 systemd[1]: PID 7966 read from file /var/run/haproxy.pid does not exist or is a zombie.
Feb 07 07:22:21 apl00086i3 systemd[1]: Reloaded SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments…
Feb 07 07:22:21 apl00086i3 haproxy[7968]: Shutting down haproxy: [FAILED]
I then issued:
journalctl shows this worked:
Feb 07 07:23:42 apl00086i3 systemd[1]: Starting SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments…
Feb 07 07:23:42 apl00086i3 haproxy[8012]: Starting haproxy: [ OK ]
Feb 07 07:23:42 apl00086i3 systemd[1]: Started SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments…
I then tried again with a systemctl reload command, which again failed:
Feb 07 07:25:10 apl00086i3 systemd[1]: PID 8037 read from file /var/run/haproxy.pid does not exist or is a zombie.
Feb 07 07:25:10 apl00086i3 systemd[1]: Reloaded SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments…
Feb 07 07:25:10 apl00086i3 haproxy[8039]: Shutting down haproxy: [FAILED]
… and then restarted:
Feb 07 07:25:26 apl00086i3 systemd[1]: Starting SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments…
Feb 07 07:25:26 apl00086i3 haproxy[8063]: Starting haproxy: [ OK ]
Feb 07 07:25:26 apl00086i3 systemd[1]: Started SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments…
I then tried again, back to the original script:
Feb 07 07:26:31 apl00086i3 haproxy[8092]: Proxy http_frontend started.
Feb 07 07:26:31 apl00086i3 systemd[1]: Reloaded SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments…
Feb 07 07:26:31 apl00086i3 systemd[1]: haproxy.service: main process exited, code=killed, status=9/KILL
Feb 07 07:26:31 apl00086i3 haproxy[8095]: Shutting down haproxy: [FAILED]
Feb 07 07:26:31 apl00086i3 systemd[1]: Unit haproxy.service entered failed state.
Feb 07 07:26:31 apl00086i3 systemd[1]: haproxy.service failed.
… note that it still refers to ‘haproxy.service’ despite using an old-style script … ??
Finally clean start again:
Feb 07 07:26:41 apl00086i3 systemd[1]: Starting SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments…
Feb 07 07:26:41 apl00086i3 haproxy[8118]: Starting haproxy: [ OK ]
Feb 07 07:26:41 apl00086i3 systemd[1]: Started SYSV: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited for high availability environments…
I may have muddied the waters a little by trying both the systemd command and the old-style script, but the fact is that reload under neither command works - and we need it to; this is a production service that needs to be able to take one load-balanced server out of the loop while it’s being upgraded without impact to the service. Restarting each time is no good, as that kills off connections; we need the reload command to work.
For info, this is the /etc/init.d/haproxy script that was installed with the haproxy installation:
#!/bin/sh
chkconfig: - 85 15
description: HA-Proxy is a TCP/HTTP reverse proxy which is particularly suited \
for high availability environments.
processname: haproxy
config: /etc/haproxy/haproxy.cfg
pidfile: /var/run/haproxy.pid
Script Author: Simon Matter simon.matter@invoca.ch
Version: 2004060600
Source function library.
if [ -f /etc/init.d/functions ]; then
. /etc/init.d/functions
elif [ -f /etc/rc.d/init.d/functions ] ; then
. /etc/rc.d/init.d/functions
else
exit 0
fi
Source networking configuration.
. /etc/sysconfig/network
Check that networking is up.
[ “${NETWORKING}” = “no” ] && exit 0
This is our service name
BASENAME=basename $0
if [ -L $0 ]; then
BASENAME=find $0 -name $BASENAME -printf %l
BASENAME=basename $BASENAME
fi
BIN=/usr/sbin/$BASENAME
CFG=/etc/$BASENAME/$BASENAME.cfg
[ -f $CFG ] || exit 1
PIDFILE=/var/run/$BASENAME.pid
LOCKFILE=/var/lock/subsys/$BASENAME
RETVAL=0
start() {
quiet_check
if [ $? -ne 0 ]; then
echo "Errors found in configuration file, check it with ‘$BASENAME check’."
return 1
fi
echo -n "Starting $BASENAME: "
daemon $BIN -D -f $CFG -p PIDFILE RETVAL=?
echo
[ $RETVAL -eq 0 ] && touch $LOCKFILE
return $RETVAL
stop() {
echo -n "Shutting down $BASENAME: "
killproc BASENAME -USR1 RETVAL=?
echo
[ $RETVAL -eq 0 ] && rm -f $LOCKFILE
[ $RETVAL -eq 0 ] && rm -f $PIDFILE
return $RETVAL
restart() {
quiet_check
return 1
fi
stop
start
reload() {
if ! [ -s $PIDFILE ]; then
return 0
fi
quiet_check
return 1
fi
$BIN -D -f $CFG -p PIDFILE -sf (cat $PIDFILE)
check() {
$BIN -c -q -V -f $CFG
quiet_check() {
$BIN -c -q -f $CFG
rhstatus() {
status $BASENAME
condrestart() {
[ -e $LOCKFILE ] && restart || :
See how we were called.
case "1" in start) start ;; stop) stop ;; restart) restart ;; reload) reload ;; condrestart) condrestart ;; status) rhstatus ;; check) check ;; *) echo "Usage: $BASENAME {start|stop|restart|reload|condrestart|status|check}"
exit 1
esac
exit $?
Is this something that I should raise on the mailing list? We need this functionality to work, and it currently isn’t.
thanks
I recently had to rebuilt my CentOS 7 HAproxy box, in order to use the systemd wrapper you’ll need to copy the binary which gets compiled with HAproxy to :
cp haproxy-systemd-wrapper /usr/local/sbin/haproxy-systemd-wrapper
Then paste the following systemd script into the following location :
/usr/lib/systemd/system/haproxy.service
[Unit]
After=network.target
[Service]
ExecStartPre=/usr/local/sbin/haproxy -f /etc/haproxy/haproxy.cfg -c -q
ExecStart=/usr/local/sbin/haproxy-systemd-wrapper -f /etc/haproxy/haproxy.cfg -p /run/haproxy.pid
KillMode=mixed
Restart=always
[Install]
WantedBy=multi-user.target
Then issue a daemon reoload : systemctl daemon-reload
Followed by enabling and starting the service :
systemctl enable haproxy
systemctl start haproxy
It worked for me on a fresh install although there is probably an easier way…
