I am having problems making requests through the balancer with websockets.
I have a client that uses socket.io.client to connect to the server.
Then there is a haproxy as a round robin balancer, which distributes connections to two identical servers but on a different port.
If I make a normal request, the balancing works correctly, but when I make one that uses websocket it does not work, I get the following error:
The file haproxy.cfg:
1 │ global
2 │ log 127.0.0.1 local0
3 │ log 127.0.0.1 local1 notice
4 │ maxconn 2000
5 │ daemon
6 │
7 │ defaults
8 │ log global
9 │ mode http
10 │ option httplog
11 │ option redispatch
12 │ retries 3
13 │ timeout connect 5s
14 │ timeout client 50s
15 │ timeout server 50s
16 │
17 │ frontend websocket_frontend
18 │ bind *:8081
19 │ option httplog
20 │ option forwardfor
21 │ option http-server-close
22 │ acl is_websocket hdr(Upgrade) -i WebSocket
23 │ use_backend websocket_backend if is_websocket
24 │ default_backend http_backend
25 │
26 │ backend websocket_backend
27 │ option http-server-close
28 │ timeout tunnel 1h
29 │ server server1 10.201.2.234:8082 check
30 │ server server2 10.201.2.234:8084 check
31 │
How can I solve it?
