Not balancing in a round'n'robin behaving
Hi Folks, hope you all are doing well.
I’ve setup a HAproxy instance to balance two “identical” servers.
The setup is working, but when I execute stress tests on that the sup07 (the balancer), looks like machine sup05 gets two times more requests than machine sup06.
The setup is:
[root@sup07 ~]# cat /etc/haproxy/haproxy.cfg
frontend Calls_Pool_Diagnostics
bind *:8680/RTDM/PoolDiangostics.jsp
default_backend Balances_Pool_Diagnostics
server sup05 sup05.brzsupport.sashq-d.openstack.sas.com:8680/RTDM/PoolDiagnostics.jsp check
server sup06 sup06.brzsupport.sashq-d.openstack.sas.com:8680/RTDM/PoolDiagnostics.jsp check
frontend Calls_RTDM_Event
bind *:8680/RTDM/Event
default_backend Balances_RTDM_Event_requests
server sup05 sup05.brzsupport.sashq-d.openstack.sas.com:8680/RTDM/Event check
server sup06 sup06.brzsupport.sashq-d.openstack.sas.com:8680/RTDM/Event check
frontend HAProxy_page
stats uri /haproxy?stats
backend http_back
Could you help me understand why is it behaving like this?
I appreciate your help.
Take into account that HAProxy does implement HTTP keep-alive both for the frontend and backend side of the connections. Therefore depending on how you benchmark (which could also be using keep-alive) it might skew the results.
However in my experience if one uses the option forceclose in the backend, then an almost perfect round-robin behaviour emerges. (Although I would use this option only with backends that target a service on the same machine as the balancer.)
