Haproxy balance roundrobin
Dear Friends,
I have a doubt
My backend has only 2 servers (vmp103 and vmp104)
You can perform the balancing as follows:
2 requests for vmp103 and 2 requests for VMP104
By the settings the balancemaneto is being done as follows:
1 request for vmp103 and 1 request for vmp104
Is it possible to balance 2 to 2 instead of 1 to 1?
Follows my settings
user root
group root
stats uri /stats
frontend http_front
bind *:8089
default_backend http_back
backend http_back
option httpchk GET /intacesso/intstatus.do?perfil=HTTP_APROVREQ
server vmp103 10.50.50.103:8080 check
server vmp104 10.50.50.104:8080 check
Best Regards
with stickness you may perform this behavior.
for so:
cookie WEBSRV insert
server vmp103 10.50.50.103:8080 cookie srv1 check
server vmp104 10.50.50.104:8080 cookie srv2 check
And with curl you should use like: curl <IP_HAPROXY_SERVER> --cookie “WEBSRV=srv1” ### if you want stickness on vmp103, else use srv2 instead of srv1 in curl command above.
