HAPROXY send 2 requests at time (roundrobin strange behavior )
I’m novice in HAPROXY, i’am using 1.8 V
bellow my roundrobin configuration :
frontend Loadbalancer_Prod
default_backend Nodes_Prod
backend Nodes_Prod
server AMASERVER1 x.x.x.x:port1 check
server AMASERVER2 x.x.x.x:port2 check
frontend Loadbalancer_Test
bind *:8080
default_backend Nodes_Test
backend Nodes_Test
bind *:88
stats uri /stats
stats auth admin:admin
The problem is when i use my Haproxy’s link one time and i see at stats i found that my proxy send tow requests at time for both servers 1 & 2 not in turns as should be in roundrobin mode
Did you have any solution for me ?
I’m not sure what you are saying. Can you provide the logs and explain based on the logs the difference between what you see and what you expect?
When i send one http request from my LBalanced.link.com i have this in my stats :
lb-after
what i expact is to see only 1 request for SERVER1 and 0 request for SERVER2
So for me Roundrobin is not working and don’t know what wrong with my conf ?!
I assume those are two different requests.
Check the haproxy logs, to get more informations.
Yes this is the problem, when i send one request from my LBalanced.link.com logs say that :
Nov 27 10:49:08 localhost haproxy[8981]: My_@IP:50209 [27/Nov/2018:10:49:08.570] Loadbalancer_Prod Nodes_Prod/SERVER1 0/0/1/1/50 200 55719 - - ---- 1/1/0/0/0 0/0 “GET / HTTP/1.1”
Nov 27 10:49:09 localhost haproxy[8981]: My_@IP:50209 [27/Nov/2018:10:49:09.112] Loadbalancer_Prod Nodes_Prod/SERVER2 0/0/1/2/4 200 55719 - - ---- 1/1/0/0/0 0/0 “GET /favicon.ico HTTP/1.1”
So effectively my loadbalancer re-send 2 requests when i send him only one
Did you have any idea what can be the root cause ? or at least can you confirm if my config is good ?
Thank you
You have 2 differents requests here :
1 for / and second one for favicon
Everything looks fine for me.
Ok i understand
Thank you for your help
