Roundrobin hiccups
Hi @ll,
I’m just testing HAPROXY, We ditching an old LB.
Pretty straight forward config, but here are issues when I hit the VIP
Seems like I’m hitting the same server over and over, when I test with curl I do get roundrobin working as expected, I know that roundrobin is not efficient but its the preferred method for our situation.
Any ideas ?
frontend https
bind *:443
default_backend app
backend app
server webapp1 ip:443 check
server webapp2 ip:443 check
How are you testing this? How do you come to this conclusion?
Hello Lukas,
Essentially I’m just refreshing site - where index.html content is different for web01 and web02.
Full config here, I would appreciate your input, since I know you are the guru here.
https://pastebin.com/2HMWAyZb
Thanks!
Your a testing in a single browser session and configured haproxy to transparently pass the entire TLS session to the backend. The browser will keep that single HTTPS connection open and use it for all transactions. There is no reason for your browser the close the HTTPS connection and it’s not technically possible for haproxy to load-balance single transactions between different backend servers, because haproxy is configured in TCP mode and only sees the encrypted TLS session.
Test with multiple browsers at the same time and you will see that round-robin takes effect in different browsers.
Lukas, and you are correct … reading your other posts, seems like you are always correct !
Thank you, funny part is that I did think about that and I tried different browsers and I could swear that it didn’t work, but it is working as expected ! THANK YOU!
