We’re using haproxy to balance both http/https traffic and some websockets. The websockets are present, but when we try to do a graceful restart (/usr/sbin/haproxy -D -f /etc/haproxy/haproxy.cfg -p /var/run/haproxy.pid -L LB1 -sf 4037) the process gets hung (But a new haproxy instance starts) until we manually close the inbound connections that are connecting to the websockets.
This will become problematic as we restart haproxy multiple times to pick up new dynamic configuration (integrated with consul using consul-templates to dynamically provision backends) and the old process won’t die until the websocket is closed on the other side, so we end up having many, many processes going.
Any recomendations on how to fix this?
HAProxy version 1.5.14
