Hi.
I have used ‘set ssl tls-key’ with the unix command in version 1.6.x.
However, in 1.7.x version, ‘set ssl tls-key’ does not execute with unknown command.
I have just changed the version, and I’m wondering why the command does not run in 1.7.x, which is the command specified in the guide.
[root@SI3012-146 ~]# haproxy -vv
HA-Proxy version 1.7.9 2017/08/18
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv
OPTIONS = USE_OPENSSL=1 USE_PCRE=1
Built without compression support (neither USE_ZLIB nor USE_SLZ are set)
Compression algorithms supported : identity(“identity”)
Built with OpenSSL version : OpenSSL 1.0.2k 26 Jan 2017
Running on OpenSSL version : OpenSSL 1.0.2k 26 Jan 2017
Built with PCRE version : 7.8 2008-09-05
Running on PCRE version : 7.8 2008-09-05
Built without Lua support
[root@SI3012-146 ~]# echo “show tls-keys *” | /usr/bin/socat stdio /var/run/haproxy.stat1
id secret
0 (/etc/haproxy/ssl/tls-ticket.key)
0.0 Wvd6NYlEbXZQc2y26RoipMaXDemegdx7lkE3cWqDHVfxGMPEEMrnhSYkZ5qEL72e
0.1 U2zwaYtNmjmhID7uDOVS+Uvu/2nQcAoyAndHfTNDqT2Yw3QWiajLkIf7dlrdB1Il
0.2 9dGgFVZnSGV2rKQRtAj8lgw4EPlBjF1rnknsOiDlbXUeu0b2HoEqWl5qPqmVWM7N
[root@SI3012-146 ~]# echo “set ssl tls-key /etc/haproxy/ssl/tls-ticket.key Md204uGmRboB2gtcHPEa/2GxYnvayIBNY7Vr/YRFX9OgfyzFabQp6PccYhlJ8vzs” | /usr/bin/socat stdio /var/run/haproxy.stat1
Unknown command. Please enter one of the following commands only :
help : this message
prompt : toggle interactive mode with prompt
quit : disconnect
show tls-keys [id|*]: show tls keys references or dump tls ticket keys when id specified
set maxconn global : change the per-process maxconn setting
set rate-limit : change a rate limiting value
set timeout : change a timeout setting
show env [var] : dump environment variables known to the process
show stat resolvers [id]: dumps counters from all resolvers section and
associated name servers
add acl : add acl entry
clear acl : clear the content of this acl
del acl : delete acl entry
get acl : report the patterns matching a sample for an ACL
show acl [id] : report available acls or dump an acl’s contents
add map : add map entry
clear map : clear the content of this map
del map : delete map entry
get map : report the keys and values matching a sample for a map
set map : modify map entry
show map [id] : report available maps or dump a map’s contents
show pools : report information about the memory pools usage
show sess [id] : report the list of current sessions or dump this session
shutdown session : kill a specific session
shutdown sessions server : kill sessions on a server
clear counters : clear max statistics counters (add ‘all’ for all counters)
show info : report information about the running process
show stat : report counters for each proxy and server
show errors : report last request and response errors for each proxy
clear table : remove an entry from a table
set table [id] : update or create a table entry’s data
show table [id]: report table usage stats or dump this table’s contents
disable frontend : temporarily disable specific frontend
enable frontend : re-enable specific frontend
set maxconn frontend : change a frontend’s maxconn setting
show servers state [id]: dump volatile server information (for backend )
show backend : list backends in the current running config
shutdown frontend : stop a specific frontend
disable agent : disable agent checks (use ‘set server’ instead)
disable health : disable health checks (use ‘set server’ instead)
disable server : disable a server for maintenance (use ‘set server’ instead)
enable agent : enable agent checks (use ‘set server’ instead)
enable health : enable health checks (use ‘set server’ instead)
enable server : enable a disabled server (use ‘set server’ instead)
set maxconn server : change a server’s maxconn setting
set server : change a server’s state, weight or address
get weight : report a server’s current weight
set weight : change a server’s weight (deprecated)
=> ‘set ssl tls-key’ is not listed
please help me
