Hi All
When I start the haproxy service , it will appear below error message:
[ALERT] 066/123408 (6612) : parsing [/etc/haproxy/haproxy.cfg:24] : ‘bind 192.168.0.1:443’ unknown keyword ‘ssl’.
how to fix this error ?
Below is the openssl version and haproxy version:
Openssl Version: 1.0.2K
Haproxy Version: 1.7.2
Below is the detail after run haproxy -vv
HA-Proxy version 1.7.2 2017/01/13
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -DTCP_USER_TIMEOUT=18
OPTIONS = USE_LINUX_TPROXY=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_PCRE=1
Running on zlib version : 1.2.3
Built with OpenSSL version : OpenSSL 1.0.2k 26 Jan 2017
Running on OpenSSL version : OpenSSL 1.0.2k 26 Jan 2017
Built with PCRE version : 7.8 2008-09-05
Running on PCRE version : 7.8 2008-09-05
Built without Lua support
Best Regards
Nudovij
