Strange cipher issue
Hi ,
I am struggling with a cipher issue and would request your input.
The haproxy is built with opensssl.I am trying to use “ssl-default-bind-ciphersuites” is global section. But haproxy compalns as
“unknown keyword ‘ssl-default-bind-ciphersuites’ in ‘global’ section”
where as it does not complain about “ssl-default-bind-options”.
Would appreciate much if you can guide me, on what I am doing wrong..
Following is my global and default section in my haproxy.cfg.
ssl-default-bind-options ssl-min-ver TLSv1.2
ssl-default-bind-ciphersuites TLS_DHE_RSA_WITH_AES_256_GCM_SHA384
user otn
group otn
tune.http.maxhdr 32767
tune.maxrewrite 1024
    tune.bufsize 163840
    master-worker
backlog 4096
timeout client 30m
timeout connect 1m
timeout server 30m
timeout tunnel 30m
timeout http-request 60m
timeout queue 10s
maxconn 10000
option accept-invalid-http-response
default-server inter 3s rise 2 fall 3 init-addr last,libc,none
haproxy -vv
HA-Proxy version 2.0.14 2020/04/02 - https://haproxy.org/
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
OPTIONS = USE_PCRE=1 USE_OPENSSL=1 USE_LUA=1 USE_ZLIB=1 USE_SYSTEMD=1
Feature list : +EPOLL -KQUEUE -MY_EPOLL -MY_SPLICE +NETFILTER +PCRE -PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED -REGPARM -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H -VSYSCALL +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -MY_ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with multi-threading support (MAX_THREADS=64, default=12).
h2 : mode=HTTP side=FE mux=H2
: mode=HTX side=FE|BE mux=H1
: mode=TCP|HTTP side=FE|BE mux=PASS
Available services : none
thanks a lot.
Tridev
ssl-default-bind-ciphersuites is for TLSv1.3 only and requires OpenSSL 1.1.1, just as the documentation says:
This setting is only available when support for OpenSSL was built in and OpenSSL 1.1.1 or later was used to build HAProxy. It sets the default string describing the list of cipher algorithms (“cipher suite”) that are negotiated during the TLSv1.3 handshake for all “bind” lines which do not explicitly define theirs.
Maybe you want ssl-default-bind-ciphers instead?
Another thing:
TLS_DHE_RSA_WITH_AES_256_GCM_SHA384 is a =< TLSv1.2 cipher, it’s also the IANA name, not the Openssl name, so this needs to be a) ssl-default-bind-ciphers and b) DHE-RSA-AES256-GCM-SHA384 :
ssl-default-bind-ciphers DHE-RSA-AES256-GCM-SHA384
@tridevk So kind of you for this post. Actually i was facing same problem i tried my best but all in wane. Then i saw your post it gave my error solution. Thanks for sharing the solution of this error. :slightly_smiling_face:
My Apologies for not coming back earlier.
Thank you @lukastribus for pointing out the ssl version and suggestion to ssl-default-bind-ciphers.
it worked brilliantly.
Thank you again.
