Haproxy url rewrite and masking
Hi All
I have a scenario here, I want to to redirect my frontend acl path_reg /foo/* to /bar/* but the /foo in the browser should not change
frontend test *:80
    acl testfoo          path_reg      /test/foo/*
   use_backend    foobackend   if testfoo
I want to rewrite the /test/foo to /newtest/foo and redirect to same foobackend, but the url in the browser should remain as /test/foo
I think the following should work:
reqrep ^([^\ :]*)\ /foo/(.*)     \1\ /bar/\2
reqrep ^([^\ :]*)\ /test/(.*)    \1\ /newtest/\2
Thanks for your reply, But am getting 404 error
i used your reqrep in the backend
reqrep ^([^\ :])\ /test/(.) \1\ /newtest/\2
Then find out why, by checking your backend logs.
This configuration does exactly what you requested:
Client request:
GET /test/foo HTTP/1.1
Host: testhost
User-Agent: curl/7.48.0
Accept: /
Request recieved at the backend server from haproxy:
GET /newtest/foo HTTP/1.1
Host: testhost
Accept: /
X-Forwarded-For: 10.0.0.4
Should i use both your reg expressions?
I used the second one alone
The second expression is to replace /test with /newtest, the first expression replaces /foo with /bar
