Here’s a small chunk of strace output (32k char post limit) I ran when both haproxy processes were using over 70% of the CPU core each. Running strace stole over 30% of CPU so haproxy’s CPU had to drop a bit. Load average was around 1.5.
Meanwhile another server with haproxy 1.6.5 consumed 35% CPU per process and load average was 0.7.
The 2 servers with high CPU usage are fully updated by the package manager. The second server hasn’t been updated for a few weeks but on the fourth server I updated haproxy alone. On that server, haproxy processes CPU usage is slightly higher, around 40% and load is around 1.0. This might be random because the traffic might not be 100% identical on all servers (different users listening to different events and different data floating around in them). I’ve attached the list of to-be-updated packages just in case. Fact is that the fully updated servers have significantly higher CPU usage compared to the unupdated one.
strace output
18:44:05.747684 gettimeofday({1473878645, 748036}, NULL) = 0
18:44:05.748246 gettimeofday({1473878645, 748294}, NULL) = 0
18:44:05.748367 epoll_wait(0, {{EPOLLIN, {u32=7276, u64=7276}}}, 200, 99) = 1
18:44:05.748537 gettimeofday({1473878645, 748580}, NULL) = 0
18:44:05.748676 time(NULL) = 1473878645
18:44:05.748897 read(7276, "\26\3\3\0F", 5) = 5
18:44:05.749099 read(7276, "\20\0\0BA\4\7\34\317\216\237 o}I\344{\10\374g<\37\356\366^\304\25C\217V\2407"..., 70) = 70
18:44:05.753852 read(7276, "\24\3\3\0\1", 5) = 5
18:44:05.754026 read(7276, "\1", 1) = 1
18:44:05.754490 read(7276, "\26\3\3\0(", 5) = 5
18:44:05.754630 read(7276, "\257\344\32N\202t1b\301\354F\361\20\3147\206D\0312\240m1\177\315$T\36\336pr/\254"..., 40) = 40
18:44:05.755026 write(7276, "\24\3\3\0\1\1\26\3\3\0(\212\310\34x\254\20\232\317c%\275\2\1\274;\371@i'\272\22"..., 51) = 51
18:44:05.755321 read(7276, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.755555 gettimeofday({1473878645, 755603}, NULL) = 0
18:44:05.755676 epoll_wait(0, {{EPOLLIN, {u32=14909, u64=14909}}, {EPOLLIN, {u32=18595, u64=18595}}, {EPOLLIN, {u32=13828, u64=13828}}, {EPOLLIN, {u32=10725, u64=10725}}, {EPOLLIN, {u32=10293, u64=10293}}, {EPOLLIN, {u32=19543, u64=19543}}, {EPOLLIN, {u32=9642, u64=9642}}, {EPOLLIN, {u32=14898, u64=14898}}}, 200, 98) = 8
18:44:05.755861 gettimeofday({1473878645, 755972}, NULL) = 0
18:44:05.756077 read(14909, "\27\3\3\0\36", 5) = 5
18:44:05.756206 read(14909, "\0\0\0\0\0\0\0\v\262\373\4\23\2Y\21r\"Z`\33K\234\337\317\226s\241`*?", 30) = 30
18:44:05.756362 read(14909, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.756574 send(5384, "\212\200\375\377\227\244", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.756909 read(14898, "\27\3\3\1\303", 5) = 5
18:44:05.757101 read(14898, "\341\330\211\274;\237\257u\351\310>`\205\257\276P,\4O\372\27\1\205\316\3638\305\311\320\345\366\307"..., 451) = 451
18:44:05.757324 read(9642, "\27\3\3\0\36", 5) = 5
18:44:05.757487 read(9642, "\304\322\272_\23\237_\323\0\311\271\322\347\312\10c\36-\265\236\214\204\341\277^!\21\203\362\304", 30) = 30
18:44:05.757815 read(9642, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.757973 send(18596, "\212\200n%\235\261", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.758401 read(19543, "\27\3\3\0\36", 5) = 5
18:44:05.758529 read(19543, "K\363\216\323]lt)+\226RU\204\217~#\325\203\35\343\272\3\v\26\322#C\325\21\25", 30) = 30
18:44:05.758660 read(19543, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.758806 send(6522, "\212\200\362\22\370\304", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.759025 read(10293, "\27\3\3\0\36", 5) = 5
18:44:05.759155 read(10293, "\0\0\0\0\0\0\0\253M\3578\7\t\rw\2126\260\246\332\225\232Y.\365\201\344\203\305p", 30) = 30
18:44:05.759381 read(10293, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.759535 send(5209, "\212\2004,\274\376", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.759735 recv(10725, "\211\0", 16384, 0) = 2
18:44:05.759902 write(17412, "\27\3\3\0\32\307e\255\25[\252\343<\345\323\374\272B\352\310\250V\202\17cS\7\n\37\312\242", 31) = 31
18:44:05.760140 recv(13828, "\211\0", 16384, 0) = 2
18:44:05.760301 write(4874, "\27\3\3\0\32\351\265I\"#\304\314\331\373\275\30DyptSS\200;-\24\216\306z\0244", 31) = 31
18:44:05.760565 recv(18595, "\211\0", 16384, 0) = 2
18:44:05.760765 write(20990, "\27\3\3\0\32oU\267\376\320\215 \261\"N\16;eh\350\200E\264\276l} \221\266\327\270", 31) = 31
18:44:05.761045 socket(PF_INET, SOCK_STREAM, IPPROTO_TCP) = 4385
18:44:05.761232 fcntl64(4385, F_SETFL, O_RDONLY|O_NONBLOCK) = 0
18:44:05.761529 setsockopt(4385, SOL_TCP, TCP_NODELAY, [1], 4) = 0
18:44:05.761739 connect(4385, {sa_family=AF_INET, sin_port=htons(2000), sin_addr=inet_addr("10.128.21.102")}, 16) = -1 EINPROGRESS (Operation now in progress)
18:44:05.762053 gettimeofday({1473878645, 762161}, NULL) = 0
18:44:05.762258 epoll_wait(0, {{EPOLLIN, {u32=5112, u64=5112}}, {EPOLLIN, {u32=6883, u64=6883}}, {EPOLLIN, {u32=8, u64=8}}, {EPOLLIN, {u32=12603, u64=12603}}, {EPOLLIN, {u32=15154, u64=15154}}}, 200, 0) = 5
18:44:05.762462 gettimeofday({1473878645, 762512}, NULL) = 0
18:44:05.762666 send(4385, "GET /websocket HTTP/1.1\r\nUpgrade"..., 460, MSG_DONTWAIT|MSG_NOSIGNAL) = 460
18:44:05.762849 recv(15154, "\211\0", 16384, 0) = 2
18:44:05.763035 write(4090, "\27\3\3\0\32\320H*\222\f\265\330\307><\37P\310\236\222\343\337i\261\353\21t\357T0\310", 31) = 31
18:44:05.763329 recv(12603, "\211\0", 16384, 0) = 2
18:44:05.763491 write(14702, "\27\3\3\0\32\267\254\252\302\330\215\307\356\346\261h\365\21PS:&)\262\231R\303\313c\0\265", 31) = 31
18:44:05.763706 accept4(8, {sa_family=AF_INET, sin_port=htons(37298), sin_addr=inet_addr("85.49.223.151")}, [16], SOCK_NONBLOCK) = 4963
18:44:05.763989 setsockopt(4963, SOL_TCP, TCP_NODELAY, [1], 4) = 0
18:44:05.764323 accept4(8, 0xbfd6367c, [128], SOCK_NONBLOCK) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.764505 time(NULL) = 1473878645
18:44:05.764663 read(4963, "\26\3\1\0\301\1\0\0\275\3\3", 11) = 11
18:44:05.764901 time(NULL) = 1473878645
18:44:05.765043 read(4963, "W\331\232u\345\372_qOP3M\367\301}\2265\25\367P\225\333\221\343A^R\226[\21%\256"..., 187) = 187
18:44:05.765210 time(NULL) = 1473878645
18:44:05.765532 time(NULL) = 1473878645
18:44:05.795498 write(4963, "\26\3\3\0]\2\0\0Y\3\3x)7\347U\313UG2DW,q\247\352\242\313\10\34I\347"..., 2931) = 2931
18:44:05.795708 read(4963, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.795823 recv(6883, "\211\0", 16384, 0) = 2
18:44:05.795978 write(17379, "\27\3\3\0@\363\360\244\314\273\244*\271B\2229\35\260\25\203\262\35&\223\0\312|\355\340\245t\357"..., 69) = 69
18:44:05.796111 read(5112, "\27\3\3\1\320", 5) = 5
18:44:05.796281 read(5112, "\243\357\205\262}M}\10\333%\v\272\347\223\235p\303\31.\30\225\25\367\215sL\311\235^\303W\344"..., 464) = 464
18:44:05.796389 read(14898, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.796559 socket(PF_INET, SOCK_STREAM, IPPROTO_TCP) = 21184
18:44:05.796650 fcntl64(21184, F_SETFL, O_RDONLY|O_NONBLOCK) = 0
18:44:05.796729 setsockopt(21184, SOL_TCP, TCP_NODELAY, [1], 4) = 0
18:44:05.796808 connect(21184, {sa_family=AF_INET, sin_port=htons(80), sin_addr=inet_addr("10.128.147.99")}, 16) = -1 EINPROGRESS (Operation now in progress)
18:44:05.796990 epoll_ctl(0, EPOLL_CTL_ADD, 4963, {EPOLLIN|EPOLLRDHUP, {u32=4963, u64=4963}}) = 0
18:44:05.797145 epoll_ctl(0, EPOLL_CTL_DEL, 5112, {0, {u32=5112, u64=5112}}) = 0
18:44:05.797228 gettimeofday({1473878645, 797255}, NULL) = 0
18:44:05.797298 epoll_wait(0, {{EPOLLIN, {u32=19979, u64=19979}}, {EPOLLIN, {u32=18157, u64=18157}}, {EPOLLIN, {u32=6366, u64=6366}}, {EPOLLIN, {u32=6993, u64=6993}}, {EPOLLIN, {u32=3214, u64=3214}}, {EPOLLIN, {u32=1526, u64=1526}}, {EPOLLIN, {u32=9147, u64=9147}}, {EPOLLIN, {u32=4985, u64=4985}}, {EPOLLIN, {u32=6411, u64=6411}}, {EPOLLIN, {u32=2387, u64=2387}}, {EPOLLIN, {u32=10858, u64=10858}}, {EPOLLIN, {u32=1044, u64=1044}}, {EPOLLIN, {u32=13393, u64=13393}}, {EPOLLIN, {u32=7351, u64=7351}}, {EPOLLIN, {u32=16762, u64=16762}}, {EPOLLIN, {u32=8265, u64=8265}}, {EPOLLIN, {u32=21849, u64=21849}}, {EPOLLIN, {u32=11011, u64=11011}}, {EPOLLIN, {u32=37, u64=37}}, {EPOLLIN, {u32=1424, u64=1424}}, {EPOLLIN, {u32=7539, u64=7539}}, {EPOLLIN, {u32=6985, u64=6985}}}, 200, 0) = 22
18:44:05.797519 gettimeofday({1473878645, 797549}, NULL) = 0
18:44:05.797639 recv(4385, "HTTP/1.1 101 Switching Protocols"..., 15360, 0) = 129
18:44:05.797746 recv(6985, "\211\0", 16384, 0) = 2
18:44:05.797859 write(2917, "\27\3\3\0\32\334sru\306^mN\255\243<\371\245s\373_\212\206\17\25\27\204\7\351O ", 31) = 31
18:44:05.797981 read(7539, "\27\3\3\0\36", 5) = 5
18:44:05.798103 read(7539, "\0\0\0\0\0\0\00066\220\247Id\ns\251\233\240>\200H0\204\10\363w\33`E\36", 30) = 30
18:44:05.798257 read(7539, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.798357 send(5286, "\212\200\7N\tz", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.798454 read(1424, "\27\3\3\0\36", 5) = 5
18:44:05.798530 read(1424, "\0\0\0\0\0\0\0\16\320\325\307\37\364S\227k\31.(\1H\20\23\\\\5 7j\t", 30) = 30
18:44:05.798715 read(1424, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.798860 send(15691, "\212\20060\377\330", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.798990 read(37, "\27\3\3\1\341", 5) = 5
18:44:05.799069 read(37, "\351\242\215\16\213r}o7\1\250o\1*\374\254\0211\21\256\224\363\3p\6\374\322\201\3646\363\37"..., 481) = 481
18:44:05.799172 recv(11011, "\211\0", 16384, 0) = 2
18:44:05.799322 write(7488, "\27\3\3\0\32\1`\364\323\r\356\337\330\206\331\275\n<\253\4\246T\t\2059O\203\310\35\213\340", 31) = 31
18:44:05.799448 read(21849, "\27\3\3\0@", 5) = 5
18:44:05.799530 read(21849, "u+\261E\200\32v\2338S\360\254\260i\250\264u\24\256n\327K\22\246;p\217\202\200\207\306\311"..., 64) = 64
18:44:05.799646 read(21849, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.799741 send(21888, "\212\200\1fsU", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.799862 recv(8265, "\211\0", 16384, 0) = 2
18:44:05.799968 write(870, "\27\3\3\0\32V~\321\254h3\5\32]\220\243\244B\3456\277\273-D\360Af\2O\210\7", 31) = 31
18:44:05.800090 read(16762, "\27\3\3\0\36", 5) = 5
18:44:05.800170 read(16762, "\0\0\0\0\0\0\0\26U}\243\352\276\240}*Z)\10H\22b\0211\375\3564\257ZW", 30) = 30
18:44:05.800253 read(16762, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.800436 send(15080, "\212\200\26\360i\342", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.800579 recv(7351, "\211\0", 16384, 0) = 2
18:44:05.800715 write(55, "\27\3\3\0@X\32V\240\22041\246\255\367A'\367\334\220}O\216.&\227\335E\224Vn\220"..., 69) = 69
18:44:05.800852 recv(13393, "\211\0", 16384, 0) = 2
18:44:05.800946 write(4747, "\27\3\3\0\32j\324MCy\352!\336\305\316\312~\30\346\2\350\310l\10\350\201\267@]\0\245", 31) = 31
18:44:05.801072 recv(1044, "\211\0", 16384, 0) = 2
18:44:05.801177 write(4496, "\27\3\3\0\32\313\201\251\20\300\217.\306\\\213\321\16P\371yt7u\372\264\261\256\220\302\235Q", 31) = 31
18:44:05.801295 read(10858, "\27\3\1\0 ", 5) = 5
18:44:05.801373 read(10858, "\251\355~\v$\215\367\277A0\350\271w\275\353W\307\261\267\276\1\306\227\312\340x\307\302\276\242p\25", 32) = 32
18:44:05.801475 read(10858, "\27\3\1\0 ", 5) = 5
18:44:05.801551 read(10858, "\n|\27\267\237=\373\250\344\313k\3\325`\350=\202\30iU_\366\251\0c\276\201\322z\206\355v", 32) = 32
18:44:05.801650 read(10858, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.801744 send(12405, "\212\200\344\22672", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.801866 recv(2387, "\211\0", 16384, 0) = 2
18:44:05.802009 write(14420, "\27\3\3\0\32\314\220\360x\342\31\334\257F\326\2237\354\344\225\221\314O\255YLPP\10\343\220", 31) = 31
18:44:05.802190 read(6411, "\27\3\3\0\36", 5) = 5
18:44:05.802278 read(6411, "\0\0\0\0\0\0\1\34\363\36\311\317\334K=\24\34\274\260S=D\224/NI\225\4O\n", 30) = 30
18:44:05.802361 read(6411, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.802451 send(9511, "\212\200\263\347~\337", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.802566 read(4985, "\27\3\3\0\36", 5) = 5
18:44:05.802645 read(4985, "f\252h\233\32\260O\342U\36\t\177qZ\235\177'NB\331\216G,\230\263\303r\200\267\32", 30) = 30
18:44:05.802726 read(4985, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.802857 send(2103, "\212\200!B\223\0", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.802983 recv(9147, "\211\0", 16384, 0) = 2
18:44:05.803075 write(8365, "\27\3\3\0\32\355\251\337*\234c\266YR\320\3231\236o\254\231re}5\254\0044\26\263\6", 31) = 31
18:44:05.803194 recv(1526, "\211\0", 16384, 0) = 2
18:44:05.803304 write(17764, "\27\3\3\0\32I`\16#\223\215\375V\35:\36\rn\n\304$\356|K\366\37\314Yq\244\344", 31) = 31
18:44:05.803456 recv(3214, "\211\0", 16384, 0) = 2
18:44:05.803565 write(12751, "\27\3\3\0\32\267N\7\262#\0\30G\314F\221\205\251\370\317\351/\356\355\177_\373\322+$\313", 31) = 31
18:44:05.803704 recv(6993, "\211\0", 16384, 0) = 2
18:44:05.803863 write(2470, "\27\3\3\0\0325\335\343\217\f\325\255`\343I3\366U\314\226\5AA<n\336\315\345W\241\313", 31) = 31
18:44:05.804005 recv(6366, "\211\0", 16384, 0) = 2
18:44:05.804113 write(15615, "\27\3\3\0\32\n\205g:\27]\374;\307\3312\0\226\232\210!\314\313&/\2446RO\342U", 31) = 31
18:44:05.804299 recv(18157, "\211\0", 16384, 0) = 2
18:44:05.804410 write(19927, "\27\3\3\0\32\t@\222C\313%\24^{\267\376\374\236\223\330\350(H\21\t\324L0F\204\352", 31) = 31
18:44:05.804597 recv(19979, "\211\0", 16384, 0) = 2
18:44:05.804820 write(8503, "\27\3\3\0\32\243\312\262\224\365\223\v\256\35\316\307\23\32F`9\205~\211\233\7eY\260x\344", 31) = 31
18:44:05.804939 send(21184, "GET /assets/scaledrone.min.js HT"..., 452, MSG_DONTWAIT|MSG_NOSIGNAL) = 452
18:44:05.805105 socket(PF_INET, SOCK_STREAM, IPPROTO_TCP) = 21962
18:44:05.805190 fcntl64(21962, F_SETFL, O_RDONLY|O_NONBLOCK) = 0
18:44:05.805267 setsockopt(21962, SOL_TCP, TCP_NODELAY, [1], 4) = 0
18:44:05.805345 connect(21962, {sa_family=AF_INET, sin_port=htons(2000), sin_addr=inet_addr("10.128.19.166")}, 16) = -1 EINPROGRESS (Operation now in progress)
18:44:05.805505 gettimeofday({1473878645, 805538}, NULL) = 0
18:44:05.805584 epoll_wait(0, {{EPOLLIN, {u32=12168, u64=12168}}, {EPOLLIN|EPOLLRDHUP, {u32=11958, u64=11958}}, {EPOLLIN, {u32=1882, u64=1882}}, {EPOLLIN, {u32=4891, u64=4891}}, {EPOLLIN, {u32=2261, u64=2261}}, {EPOLLIN, {u32=2150, u64=2150}}, {EPOLLIN, {u32=3282, u64=3282}}, {EPOLLIN, {u32=3836, u64=3836}}, {EPOLLIN, {u32=20248, u64=20248}}}, 200, 0) = 9
18:44:05.805705 gettimeofday({1473878645, 805800}, NULL) = 0
18:44:05.805865 write(14898, "\27\3\3\0\231\2079\312u\311\352\22\213\302\211g\365\306\366\244\v\261Z\343\251\312\302e\343\315\212\212"..., 158) = 158
18:44:05.806034 recv(20248, "\211\0", 16384, 0) = 2
18:44:05.806306 write(19682, "\27\3\3\0\32KlW^\242\341\33q\263c\214\2028\275\261\23w\253nK\2217+\2026\22", 31) = 31
18:44:05.806464 read(3836, "\27\3\3\0\36", 5) = 5
18:44:05.806545 read(3836, "T\374\n5\342\211x\265[{.\226t\250\374o\305|\330\252\360\2155\224\324\306\270k\341\24", 30) = 30
18:44:05.806628 read(3836, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.806842 send(1337, "\212\200\323\332\37:", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.807069 read(3282, "\27\3\3\0\36", 5) = 5
18:44:05.807256 read(3282, "\0\0\0\0\0\0\0R\352\274\354tz\321\304}\330\211uv\334\266\262\324w\t\233rW\17", 30) = 30
18:44:05.807445 read(3282, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.807707 send(16303, "\212\200\272'\226\340", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.807856 read(2150, "\27\3\3\0\36", 5) = 5
18:44:05.807937 read(2150, "\10\254\322\350\316)V/\317\231X\177j*^\306\375\v\364\4zk\223_\336F\267P\350r", 30) = 30
18:44:05.808021 read(2150, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.808151 send(5898, "\212\200\200\225[\231", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.808282 recv(2261, "\211\0", 16384, 0) = 2
18:44:05.808374 write(7972, "\27\3\3\0\32BL\5\216S\252\244\317X\234n\177\211\7\211\245\214\275\5f\332\322\230V\265\n", 31) = 31
18:44:05.808571 read(4891, "\27\3\3\0\36", 5) = 5
18:44:05.808665 read(4891, "\0\0\0\0\0\0\1\27\203\3257H\6\320\17<'\224\346q\4\20\207\0\276_\206\225U\17", 30) = 30
18:44:05.808750 read(4891, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.808841 send(12758, "\212\200\242\345\340\211", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.808944 recv(1882, "\211\0", 16384, 0) = 2
18:44:05.809234 write(1255, "\27\3\3\0\32\341\1%A\6\345B\244\300\10\322\353\206\342jyE\351Y9\7x\312\4MH", 31) = 31
18:44:05.809375 read(11958, "", 5) = 0
18:44:05.809478 read(12168, "\27\3\3\0\36", 5) = 5
18:44:05.809560 read(12168, "\207e\310}\24\210\372P\375C\252I\n\255\237\3016\215\300\234\37\315\376k\177\342\240n\371\214", 30) = 30
18:44:05.809645 read(12168, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.809735 send(9069, "\212\200\372o\355U", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.809855 recv(21184, "HTTP/1.1 304 Not Modified\r\nServe"..., 15360, 0) = 240
18:44:05.809946 read(37, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.810037 send(21962, "GET /websocket HTTP/1.1\r\nUpgrade"..., 489, MSG_DONTWAIT|MSG_NOSIGNAL) = 489
18:44:05.810272 recv(4385, 0xbf1d8680, 16384, 0) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.810362 shutdown(8468, SHUT_WR) = 0
18:44:05.810512 setsockopt(21184, SOL_SOCKET, SO_LINGER, {onoff=1, linger=0}, 8) = 0
18:44:05.810592 close(21184) = 0
18:44:05.810787 epoll_ctl(0, EPOLL_CTL_DEL, 11958, {0, {u32=11958, u64=11958}}) = 0
18:44:05.810879 epoll_ctl(0, EPOLL_CTL_ADD, 4385, {EPOLLIN|EPOLLRDHUP, {u32=4385, u64=4385}}) = 0
18:44:05.810955 gettimeofday({1473878645, 810981}, NULL) = 0
18:44:05.811024 epoll_wait(0, {{EPOLLIN, {u32=18573, u64=18573}}, {EPOLLIN, {u32=3392, u64=3392}}, {EPOLLIN, {u32=8171, u64=8171}}, {EPOLLIN, {u32=9383, u64=9383}}, {EPOLLIN|EPOLLHUP|EPOLLRDHUP, {u32=8468, u64=8468}}}, 200, 0) = 5
18:44:05.811118 gettimeofday({1473878645, 811143}, NULL) = 0
18:44:05.811312 write(5112, "\27\3\3\0\371\366(l\254\2\271\261\362\307\341\230U0G\6%\330\304\357\223]Kd\347c\300\35"..., 254) = 254
18:44:05.811444 write(5112, "\25\3\3\0\32\366(l\254\2\271\261\363\221yN\337\23\5\2739\4\303\216D\256\35}\254_d", 31) = 31
18:44:05.811632 shutdown(5112, SHUT_WR) = 0
18:44:05.811768 close(5112) = 0
18:44:05.811863 recv(8468, "", 16384, 0) = 0
18:44:05.812056 close(8468) = 0
18:44:05.812189 recv(9383, "\211\0", 16384, 0) = 2
18:44:05.812285 write(20502, "\27\3\3\0\32g\362\203\22~lo#\"4\212\226\3\237 \362\253\302\240\372\361hw\23\36J", 31) = 31
18:44:05.812427 read(8171, "\27\3\3\0\36", 5) = 5
18:44:05.812661 read(8171, "\0\0\0\0\0\0\0F\367\206\273\3626\261\34534\250EZu\35\265\272\324V\20\24\363\n", 30) = 30
18:44:05.812774 read(8171, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.812868 send(12391, "\212\200\37\205\3544", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.812998 recv(3392, "\211\0", 16384, 0) = 2
18:44:05.813090 write(17779, "\27\3\3\0\32hD\7\343\v}\255\5\343Q3>\244\232Aue\7\374\340\273\331/8Ic", 31) = 31
18:44:05.813205 read(18573, "\27\3\3\0\36", 5) = 5
18:44:05.813338 read(18573, "\0\0\0\0\0\0\0\21\307\261\226\262~\260\265\350\16m\376\361\305\0~$W\347\365)3\224", 30) = 30
18:44:05.813428 read(18573, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.813576 send(19209, "\212\200Q*\3520", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.813734 recv(21962, "HTTP/1.1 101 Switching Protocols"..., 15360, 0) = 129
18:44:05.813933 sendmsg(9, {msg_name(110)={sa_family=AF_LOCAL, sun_path="/dev/log"}, msg_iov(8)=[{"<134>Sep 14 18:44:05 ", 21}, {"haproxy", 7}, {"[", 1}, {"4257", 4}, {"]: ", 3}, {"", 0}, {"213.143.48.211:4807 [14/Sep/2016"..., 160}, {"\n", 1}], msg_controllen=0, msg_flags=0}, MSG_DONTWAIT|MSG_NOSIGNAL) = 197
18:44:05.814514 write(11958, "\25\3\3\0\32\2\300\357\207\314\321\247\274\262@S\6\371H\327\334\2213\25Z-\2020c>\267", 31) = 31
18:44:05.814713 shutdown(11958, SHUT_WR) = 0
18:44:05.814870 close(11958) = 0
18:44:05.815006 sendmsg(9, {msg_name(110)={sa_family=AF_LOCAL, sun_path="/dev/log"}, msg_iov(8)=[{"<134>Sep 14 18:44:05 ", 21}, {"haproxy", 7}, {"[", 1}, {"4257", 4}, {"]: ", 3}, {"", 0}, {"189.154.94.136:49375 [14/Sep/201"..., 157}, {"\n", 1}], msg_controllen=0, msg_flags=0}, MSG_DONTWAIT|MSG_NOSIGNAL) = 194
18:44:05.815299 gettimeofday({1473878645, 815335}, NULL) = 0
18:44:05.815382 epoll_wait(0, {{EPOLLIN, {u32=17781, u64=17781}}, {EPOLLIN, {u32=17934, u64=17934}}, {EPOLLIN, {u32=11002, u64=11002}}, {EPOLLIN, {u32=4393, u64=4393}}, {EPOLLIN, {u32=18869, u64=18869}}}, 200, 0) = 5
18:44:05.815476 gettimeofday({1473878645, 815502}, NULL) = 0
18:44:05.815561 write(37, "\27\3\3\0\231#FTz\230\177\336\324\257WS\32\215E\240\5\331S\"6\356\233%\372e\322H"..., 158) = 158
18:44:05.815680 time(NULL) = 1473878645
18:44:05.815788 read(18869, "\26\3\3\0F", 5) = 5
18:44:05.815872 read(18869, "\20\0\0BA\4\266\372\353i\203T\275\260\227\2533\2\235\354f\t\r>\212\236\363\232Er\364\265"..., 70) = 70
18:44:05.818399 read(18869, "\24\3\3\0\1", 5) = 5
18:44:05.818572 read(18869, "\1", 1) = 1
18:44:05.818831 read(18869, "\26\3\3\0(", 5) = 5
18:44:05.818916 read(18869, "\1\350\245J\253\336\265\203\270\322\275\261\261\307\1_8A\357\224#<\351\232\3011Wq)_\260\222"..., 40) = 40
18:44:05.819207 write(18869, "\24\3\3\0\1\1\26\3\3\0([O\n3\341;>p\3%\255\216\357\314d\275\316\0336\351\366"..., 51) = 51
18:44:05.819444 read(18869, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.819539 read(4393, "\27\3\3\0\36", 5) = 5
18:44:05.819618 read(4393, "6H!A\35\342}\255\227\204\3122\200$\257\30\2526g_0\30\373\256\\\221\351\26\327\254", 30) = 30
18:44:05.819701 read(4393, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.819823 send(21357, "\212\200\320N\264\300", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.819949 read(11002, "\27\3\3\0@", 5) = 5
18:44:05.820029 read(11002, "6\244\237\221$\20\226\227\354\2An<\1\303vr\376g\25\246\353\317#h\232\237j\v\277\265\344"..., 64) = 64
18:44:05.820160 read(11002, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.820260 send(22120, "\212\2002\304DS", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.820375 read(17934, "\27\3\3\0\36", 5) = 5
18:44:05.820454 read(17934, "\0\0\0\0\0\0\0:>\6I`5\6dD@\257\30\222$a\225\223\362\353e4\301f", 30) = 30
18:44:05.820636 read(17934, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.820733 send(13738, "\212\200zy\2578", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.820847 read(17781, "\27\3\3\0\36", 5) = 5
18:44:05.820932 read(17781, "\370*Ag\304S\346\23\22109FRn\357\336\222P\313\22\352\232\267?\343:\316\213\5\361", 30) = 30
18:44:05.821065 read(17781, 0xbfbef5db, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.821160 send(19710, "\212\200/9\362^", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.821426 recv(21962, 0xbdc7bb88, 16384, 0) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.821535 epoll_ctl(0, EPOLL_CTL_ADD, 21962, {EPOLLIN|EPOLLRDHUP, {u32=21962, u64=21962}}) = 0
18:44:05.821620 gettimeofday({1473878645, 821646}, NULL) = 0
18:44:05.821689 epoll_wait(0, {{EPOLLIN, {u32=2343, u64=2343}}, {EPOLLIN, {u32=3893, u64=3893}}, {EPOLLIN, {u32=8533, u64=8533}}}, 200, 31) = 3
18:44:05.821774 gettimeofday({1473878645, 821800}, NULL) = 0
18:44:05.821845 time(NULL) = 1473878645
18:44:05.821920 read(2343, "\26\3\1\0\365\1\0\0\361\3\1", 11) = 11
18:44:05.822048 time(NULL) = 1473878645
18:44:05.822163 read(2343, "W\331\232t\255\26\250\352~\312\2031(0\331.\373\321\277\336\10\314\252_\362\272HV\37et\253"..., 239) = 239
18:44:05.822329 time(NULL) = 1473878645
18:44:05.822420 time(NULL) = 1473878645
18:44:05.822883 write(2343, "\26\3\1\0Q\2\0\0M\3\1G\23w\336\\\264b\16\202@\2516\370\177\255\247B\275\217\5\204"..., 145) = 145
18:44:05.823015 read(2343, 0xb66a600b, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.823131 time(NULL) = 1473878645
18:44:05.823210 read(8533, "\24\3\3\0\1", 5) = 5
18:44:05.823314 read(8533, "\1", 1) = 1
18:44:05.823600 read(8533, "\26\3\3\0(", 5) = 5
18:44:05.823692 read(8533, "\0\0\0\0\0\0\0\0\272k\224@\335\355&\232A\314\200<l\36I\240\353D\vKmt\266\326"..., 40) = 40
18:44:05.823849 read(8533, 0xb66a600b, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.823939 read(3893, "\27\3\3\0R", 5) = 5
18:44:05.824017 read(3893, "\0\0\0\0\0\0\0\3\314\327\264\2308\204d\255\266.\334dp\333_or\3440\377\216\311\255A"..., 82) = 82
18:44:05.824194 read(3893, 0xb66a600b, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.824299 send(21965, "\201\264\212\245\30\270\361\207y\333\376\314w\326\250\237:\313\377\307k\333\370\314z\335\250\211:\312\345\312"..., 58, MSG_DONTWAIT|MSG_NOSIGNAL) = 58
18:44:05.824421 gettimeofday({1473878645, 824451}, NULL) = 0
18:44:05.824496 epoll_wait(0, {{EPOLLIN, {u32=18893, u64=18893}}, {EPOLLIN, {u32=5337, u64=5337}}, {EPOLLIN, {u32=1699, u64=1699}}, {EPOLLIN, {u32=20000, u64=20000}}}, 200, 25) = 4
18:44:05.824587 gettimeofday({1473878645, 824613}, NULL) = 0
18:44:05.824663 read(18893, "\27\3\3\0\36", 5) = 5
18:44:05.824740 read(18893, "\0\0\0\0\0\0\0\0101\200q\352\1\224T\341\31\216\342\17@&\266\"\t\377!p\254\255", 30) = 30
18:44:05.824822 read(18893, 0xb66a600b, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.824952 send(6148, "\212\200\201,\227\371", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.825071 recv(20000, "\211\0", 16384, 0) = 2
18:44:05.825165 write(1168, "\27\3\3\0\32WB\310`\241s\217EPm{\253 \1\376{\31u\251v\177\21\265:\34\265", 31) = 31
18:44:05.825288 read(1699, "\27\3\3\0\36", 5) = 5
18:44:05.825368 read(1699, "\35n\203g\316_\302\351]\334p1\f+\317\212\243G\27/\3553z\347\354\271\244\206\323\33", 30) = 30
18:44:05.825451 read(1699, 0xb66a600b, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.825643 send(2350, "\212\200\276\366\273\303", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.825758 read(5337, "\27\3\3\0\36", 5) = 5
18:44:05.825844 read(5337, "\0\0\0\0\0\0\24dc\n\230\345\221\242\322\23C\366q\305\324\31\373\274Y\4\230\225\375\r", 30) = 30
18:44:05.825968 read(5337, 0xb66a600b, 5) = -1 EAGAIN (Resource temporarily unavailable)
18:44:05.826071 send(5641, "\212\200,\265\360[", 6, MSG_DONTWAIT|MSG_NOSIGNAL) = 6
18:44:05.826369 gettimeofday({1473878645, 826400}, NULL) = 0
18:44:05.826445 epoll_wait(0, {{EPOLLIN, {u32=21965, u64=21965}}}, 200, 22) = 1
18:44:05.826520 gettimeofday({1473878645, 826546}, NULL) = 0
18:44:05.826600 recv(21965, "\201\17{\"callback\":1}\n", 16384, 0) = 17
18:44:05.826691 write(3893, "\27\3\3\0)\6\373`\317\2218\17\f\254\267\334\357\250)\355\25\257\24\10\270\31\346u\347\275KL"..., 46) = 46
18:44:05.826811 gettimeofday({1473878645, 826841}, NULL) = 0
18:44:05.826884 epoll_wait(0, {{EPOLLIN, {u32=11291, u64=11291}}, {EPOLLIN, {u32=8446, u64=8446}}}, 200, 20) = 2
18:44:05.827038 gettimeofday({1473878645, 827066}, NULL) = 0
18:44:05.827124 recv(11291, "\211\0", 16384, 0) = 2
18:44:05.827231 write(16989, "\27\3\3\0\32;B \352\2508de\226\305\2629~{Z2^\272lO\f\2322\355qu", 31) = 31
18:44:05.827385 recv(8446, "\211\0", 16384, 0) = 2
18:44:05.827504 write(1473, "\27\3\3\0@w24k\210\20q\203i\32s\263\332\272\310\3241\257\267\227\37\376M\315\223\16\274"..., 69) = 69
18:44:05.827624 gettimeofday({1473878645, 827683}, NULL) = 0
18:44:05.827731 epoll_wait(0, {{EPOLLIN, {u32=11532, u64=11532}}, {EPOLLIN, {u32=1731, u64=1731}}}, 200, 20) = 2
18:44:05.828001 gettimeofday({1473878645, 828031}, NULL) = 0
18:44:05.828087 recv(11532, "\211\0", 16384, 0) = 2
18:44:05.828177 write(3839, "\27\3\3\0\32\330\216d\362\376:\325Yanb\265,o\22\3257\277\232\35\350\345V6\242T", 31) = 31
