Rule using even/odd from uri query parameter
Hello!
I would like to set some rules about query parameter URL, based on odd/even for example:
$ curl -I 'localhost:10001/test/?id=1' #  use one backend
$ curl -I 'localhost:10001/test/?id=2' #  user another backend
I can get the ID using
acl has_id urlp(id) -m bool
But I can’t use even function, I did’t understood the docs :frowning:
Also, I’m able to compare the id with some number, like this:
acl has_id urlp(id) -m int ge 666
But can’t see if is odd or even.
I also tried to use path_reg but this not works with uri, only with path.
Can you please help me?
Thanks!
Worked with:
acl is_odd urlp_val(id) odd -m found
Using urlp_val the value was converted to integer \m/
