I am trying to get every POST request to:
/admin/file-manager/*/do-upload, while * can be any number (0,3524,76 etc…) to specific server.
I have tried to do it like that:
acl is_upload_url path_reg ^/admin/file-manager/…/do-upload/… $
use-server myserver if is_upload_url
But it doesn’t seems to work
any suggestions?
Thanks !
arash
July 2, 2018, 4:50am
2
Hi @Orrmor94
maybe this help you :
acl is_upload_url path_reg \/admin\/file-manager\/[0-9]*\/do-upload.*
I do have a similar requirement but need to redirect to a new URL depending on the regex pattern but only if the regex matches.
Request Path: /path/to/something/filename-XX-YY.pdf
Redirect Path: /XX-YY/something
Is that possible as well?
arash
July 2, 2018, 4:31pm
4
Yes
create an ACL then use it in the condition of http-request
Sure, but how do I use XX-YY from the request to put that into the destination? My question probably wasn’t clear enough such that XX-YY is variable and should be taken from the request and put into destination.
Let me ask again:
Is it possible to use the found number by [0-9]* as a string in the redirect destination?
