Url_beg acl help
Hi guys,
I need to setup an acl as thus,
acl acl1 url_beg /start/xxx/end
where xxx changes but the start and end remains the same.
What can I use? I am not even sure if url_beg can be used for that. I got a bunch of acls working already but they all have fixed path like /download/now, /upload etc. But I do not know how to write an expression that has a variable in the middle.
Thanks in advance,
i think you should use path_reg instead. this way you can compute a regex matching the path you want.
Something like this (not tested) :
acl acl1 path_reg ^/start/.+/end$
Without using regex, try the following:
acl acl1 { path_beg /start/ } { path_end /end }
Thanks to both of you guys. Both solutions were helpful.
