Acl regex problem with "?" in URL
I have a problem with a regex to verify an URL.
I use this acl :
acl sign path_reg /signature/state?status=[a-zA-Z0-9]*$
I have a problem with the caracter “?” when I try (http://try.org/signature/state?status=666), the ACL is not accepted.
For test, I try
acl sign path_reg /signature/state.status=[a-zA-Z0-9]*$
URL : http://try.org/signature/state*status=666 => ACL OK => go to the backend
URL : http://try.org/signature/state?status=666 => ACL KO
Do you know how I can resolve this problem ?
Thanks in advance.
Regards
Thats what path is:
This extracts the request’s URL path, which starts at the first slash and
ends before the question mark
You probably need url instead.
Ok thanks.
I’m going to test wtith url_reg
This was the cause of my problem.
With the use of url_reg, it works.
acl sign url_reg /signature/state?status=[a-zA-Z0-9]*$
Thank you very much.
Have a good day
