I’m running 1.6.9 built recently with USE_PCRE=1 on my Raspberry Pi. I want to allow the URLs
http://server.mydomain.com/subdir
-or-
http://server.mydomain.com/subdir/
to match
What I tried was
acl mysubdir_req path_beg /subdir/?
using the ‘?’ PCRE regex for “0 or 1” matching but it doesn’t work.
If I remove the ? it does work as long as I include the trailing slash which is what I expected.
path_beg is not a regex.
Use
acl mysubdir_req path_reg ^/subdir/?
or better yet avoid the regex and just write:
acl mysubdir_req path_beg /subdir/ /subdir
Ah! NOT a regex? Well, I’ll have to watch out for that. Thanks!
Rfraile
4
Without using regex, if you use the last acl:
It’ll match more than desired, like this example:
/subdir/ - yes
/subdir - yes
/subdir2 - yes
/subdir/subdir/ - yes
Maybe it is better a combination of two acls:
acl mysubdir_req { path /subdir } OR { path_beg /subdir/ }
That resul on:
/subdir/ - yes
/subdir - yes
/subdir2 - not
Yes, replace path_beg with path if you want to match the path exactly.
