ACL for missing path
I want to create a separate ACL for path which does and does not contain a specific string “purchase”.
extract from my config
acl acl_p path_beg -i /purchase
use_backend  purchase if acl_p
acl non_p path_reg  !^/purchase
use_backend non_purchase if non_p
What is the correct regular expression for ACL non_p ?
Found it
^((?!p04).)*$
